Question about Keurig Elite B40 Coffee Maker
Kuerig coffee maker does not heat water
Not ready light comes on but the water does not heat
  • 1,511 Answers
Thermal guide not set properly, See manual for resetting insttructions.
Posted on Jan 31, 2014
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Posted on Mar 02, 2009
SOURCE: i just plugged the coffee maker back its not making coffee!
So folks to solve this problem I used the last resort....don't laugh, but I actually started to hit the machine very hard on the top and from the side and all of sudden it started to work. When in doubt hit it!
Posted on Oct 19, 2009
SOURCE: The Keurig coffee maker keeps turning off on its
According to their tech support...
Remove the water tank and re-seat. Unplug for 30 seconds and replug.
Fixed mine this way with the same issue.
Terry
Posted on Dec 28, 2009
Lady Spark
  • 51 Answers
SOURCE: Keurig coffee maker is on, lights lit, machine
Even though the light is on, this does not mean the element that heats the water is working. After you fill the machine with COLD water, and the light has been on for a few minutes, unplug the machine and dump the water out into a bowl. Carefully, feel the water. Is it hot? OR just warm? Or still cold? If it is warm, the element is not heating properly. If it is cold, the element is NOT working. If the water is HOT, then perhaps the tube from the water storage reservoir to the brewing basket is clogged. If that tube is clogged, it needs to be removed from the machine and cleaned out. If the element is not working, or heating the eater hot enough, that element needs replacement. Chances are, the replacement cost/cost of repair would be more then a new coffee maker.
Posted on Feb 03, 2010
NewsView
  • 40 Answers
SOURCE: My coffee maker stopped working. I got it going a
In some cases, you can also get the electronics to reset by leaving it unplugged for at least 15 minutes. This may resolve whatever is locking up the machine.
Another possibility is that it may need to be decalcified, especially if you haven't done so recently. Try looking up your model number on the web or on the manufacturer website. Download the owner's manual, if need be, and view their cleaning and troubleshooting sections. If that doesn't work, contact the manufacturer during normal business hours. The unit may require service.
Posted on Mar 06, 2010
My Kuerig B40 will not pull water from the tank
You most likely have a heating element bad or a burnt wire at the element. The water has to be drawn into by gravity and then heated so the heated water will percolate to the top. If there is no heat to that element, nothing will happen. Most coffee makers use a common element for the pot pad and the percolation process. Yours may have sepparate elements. Good Luck
Sep 01, 2014 | Coffee Makers & Espresso Machines
How do use that vinegar to the descale my kuerig machine
The BEST way that I found to fix my Kuerig after the dreaded DESCALE sign came up . Very simple and it works. All that you need is a STRAIGHTENED OUT PAPER CLIP
1..Unplug the machine
.2. Take off the water tank
.3. Lay the machine on its back
4.open the handle as if you were going to put a Kcup in
5. You will see a metal prong shaped like an arrow head . .Using a flash light makes it much easier to see There is a hole on each side of the metal prong
6.. Stick the paper clip in and out and rub it around for about 15 seconds Do that to each hole
. 7.. Up right the machine , put the water tank back on - fill with water and plug in . After it heats up , the problem should be solved. I brewed about 10 cups of plain water to try to clear out the debris . Then back to my COFFEE :)
Nov 10, 2013 | Braun Tassimo Coffee Maker
My kuerig will heat water but not dispense what can i do to fix this
The exit tube is clogged and needs to be cleaned with a paper clip end. Inset and push up to remove debris. Use Distilled water and replace filters often.
Sep 07, 2013 | Keurig B60 Coffee Maker
Kuerig lights don't flash
Handle not engaged all of the way.
Nov 22, 2012 | Keurig B50 Coffee Maker
My Kuerig coffee maker putters out the coffee, there is no fluid stream of coffee like before. The coffee maker makes the sound like coffee will come out but then there is nothing but drops.
try runing a descaler throgh it first,see if that solves the problem, after a lot of use scale builds up in most applianced using hot water
Jul 29, 2011 | Microwave Ovens
Mar 06, 2010 | Keurig Platinum B70 Coffee Maker
8543 not working
CHECK THE BLACK WIRE COMING OFF THE BOTTOM TERMINAL OF THERMOSTAT FOR VOLTAGE, IT SUPPLIES POWER FOR THE WARMER SWITCHES. THE 'READY TO BREW' LIGHT IS PROBABLY A BAD BULB.
Oct 12, 2008 | Bloomfield 8543 Coffee Maker
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
281 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
