Question about Toshiba 27D46 27" TV
How do I stop the menu loop?
The menu screen is on a continued loop and won't stop.I took the back off, so I know the button isn't stuck
    Champion:
  • 240 Answers
Press mute on the remote once and then press and hold mute and menue at same time.
An S' will appear on screen.
now you are in the service menue
press key number 9 on your remote this will perform a self Diagnostics
if this dosent work
press and hold volum on front of tv set then press 9 onthe remote.
power set off then on
youe should be reset.
Posted on Jan 14, 2009
Samsung Galaxy Note 4 - Stuck in a power up loop
Samsung Galaxy Note 4: power on off loop:
I have a Note 4 also.. When I updated to one of the newer OS it started power on off looping when the battery got to a low percentage. This would freak out any User. It is normal for many people however. It is a Google software firmware issue that will probably be fixed after the next patch update.
In the mean time, if when your battery gets really low and you get the power on off loop, just charge the device or pop in a charged battery.
There is no fix for this right now. You just have to deal with it.
If your battery is higher then 15% left and it is looping, then the possibility is that either you tried to/or the system automatically tried to update your phone, but the transfer was interrupted or corrupted some how.. could be bad connection between the towers or the WiFi router you were on.. or any number of other things.
If you are in the US, best to drop by a local Best Buy store. Call ahead and ask if they have a Samsung Experience Shop inside. Not all Best Buys have one.
Ask to have Best Buy transfer your call to the rep there if possible (I'm not sure if they have a phone there.. if not you may have to just visit the Best Buy store with the Samsung Experience Shop inside there..
Bring your device and your charging cables/adapter just in case, make sure the battery is charged).. Ask if the Samsung Manager can help you and when s/he will be available.
That person will have the knowledge and the equipment inside the Samsung Experience section to get your phone back to normal again, however note that you may lose all your data files on the phone. It most likely will have to be factory reset and possibly reFlashed with the OEM firmware.
WELCOME TOTHE SAMSUNGEXPERIENCE SHOP
Jan 09, 2016 | Samsung Galaxy Note 4G
Acer m5-581tg Auto repair loop WIndows 8?
it could be a problem with hard drive, try replacing it with a spare hd , if its still the same then maybe you could take out internal battery and put it back in ,even take out mem and put back in at same time of taking out internal battery ,it could help resolving the problems.
Mar 20, 2014 | Acer Computers & Internet
Hi samsung gio won't start stuck in first samsung screen and can't log to recovery mode it gives ramdump and stuck
ram dump if your press vol up+power+home button, but if you wanna go to download mode you must press vol down+home+power button.
it stuck on first screen called boot loop, solution is reinstall or flash new rom on your phone,
follow this http://www.droidvan.com/2012/06/link2sd-on-stock-rom-s5660dxkt8-236.html if you wanna back to stock rom
or this http://www.droidvan.com/2013/03/cm-9-final-for-galaxy-gio.html if you wanna taste off ICS on your phone
Mar 12, 2013 | Cell Phones
Blackberry 8520 won't reboot goes half way then stops took battery out left all night still won't go any further what can I do ? Please
my phone does this ever so often... you will lose all the data on the phone. with the phone off take the sdd card out and then while holding the volume button (+ or - changes from phone to phone... hold the volume camera and power button and wait for the screen you dont ever see, if you stop holding or hold the wrong volume button it will not work... then when that screen pops up hit your menu button on the touch screen, use the volume button to scroll down to system restore or what ever its called and select it with the camera button... then reboot your phone.
Feb 08, 2013 | Cell Phones
How to reset factory setting of monitor lg l1720B
Sounds to me like the button is stuck with pressure on the sensor. try moving button around a bit if it is a flat surface button then the surface is likely distorted and wont release it would have to be replaced at that point.
Sep 06, 2012 | LG L1720B 17" LCD Monitor
Lg 37lg30 stuck in a loop, it flips between AV2 and DTV1 every 2 seconds. Batteries in remote are fine. Briefly see normal picture when pressing remote buttons before the AV2/DTV1 loop continues. Managed...
Maybe there are buttons on the remote or tv set that are stuck, check these. If no luck then hide the remote so it can't communicate with the set, if it still is acting up unplugg the set for 30 min or more and plug it back in. This may clear a fault that is stuck. If it still is not working correct then the tuner is going bad. Check all devices that are plugged in to the set and unplug them from the tv so the tv does not recognize there is a device connected this may also help.
Sep 24, 2011 | LG 37LG30 37 in. LCD HDTV
Tv continues to go to menu screen (not dish menu, tv menu)
sounds like a button is stuck. Remove the battery from the remote and see if this fixes the problem
Sep 07, 2009 | Televison & Video
Menu screen keeps popping on and off during usage
Check the menu button on your monitor. Chances are it is stuck in the depressed position. (Sometimes an edge of the button will get caught beneath the frame.)
Jun 01, 2009 | Dell E157FP Monitor
Stuck in demo mode
to deactive demo mode press menu on the remote...then w/that screen up push the screen mode little gray button at the top of the remote...note that this will not change anything on the screen...i know weird huh...now type in the numbers 9012 you should now be at a new menu the top opption is demo mode...choose it and then choose on or off...good luck i see this i an old post but i hope it helps someone...
Jul 08, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Toshiba 27D46 27" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
