Question about KitchenAid KESC308LSS Electric Kitchen Range
KitchenAid Electric Range Model KESA907PSS02 surface elements and oven all stopped producing heat after initially being 'on'
The other night we were using 2 out of 4 burners plus the oven and all 3 initially produced heat. Part way through cooking, we noticed that the element knob lights were not lit up & there was no heat from the elements or oven. The display on the panel still lit up, so the range is getting power. The display works, oven light comes 'on' as does the convection fan, but there is NO heat. We thought that it might be the Thermostat Manager (#9759242 ), but we checked it and it is okay.
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
You might have blown the thermal fuse. Here is a diagram of your unit.
The fuse is number 37 on the diagram. Check it for continuity. Here is the part to order in case it is bad.
Keep me posted.
Regards,
Richard Roth
http://appliancecafe.com
For all your appliance repair needs.
Posted on Dec 09, 2012
  • KYee Dec 10, 2012
    We have that diagram, thanks. The KitchenAid parts list calls the thermal fuse a termostate manager (same part number). We reasoned that this was the part that was bad so ordered one on Friday (should get it this week), but checked the thermal fuse today, after the fact, and our multimeter shows continuity.
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
Posted on Dec 20, 2007
aborcass
  • 2651 Answers
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
  • 184 Answers
SOURCE: Kitchen Aid KESC 307 hbs4 electric range control
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Posted on Apr 04, 2008
Treefrog15
  • 127 Answers
SOURCE: Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Posted on Dec 23, 2008
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
I have a Jenn-Air JES9900 range and the right front burner is not working but the hot indicator light remains on. Is this just a switch that needs to be replaced?
make this test and fix it. God bless you
Surface Element Switch
If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Surface Element Board
If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element
If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element
The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element
If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Element Receptacle and Wire Kit
If a surface element won't work, there may be a problem in the element receptacle. The surface element plugs onto a terminal block type receptacle. Over time the terminals in the receptacle can have a bad connection and overheat. Look at the receptacle contacts with a flashlight. If the terminals look burnt you will need to replace the element receptacle. also make sure the element prongs are clean and not burnt. If the prongs are burnt bad the element will need to be replaced also.
Loose or Burnt Wire Connection
If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem
Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Nov 04, 2013 | Kitchen Ranges
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
Convection stopped working a couple of months ago, now regular oven does not come up to proper temperature, top element is red bottom element is not
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | KitchenAid KESC307 Electric Kitchen Range
Oven wont heat up
Most likely the problem will be in the control unit. Something is stopping the relays for the oven and broiler from working.
This site has a diagram of your range and a price for the part.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264337&diagram_id=123066#d123066
Jan 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
How do i replace the lower heat element on a kitchenaid oven?
The following link explains step-by-step how to replace an oven element on an ELECTRIC range:
http://www.fixya.com/support/r3575810-replacing_the_bake_or_broil_element_in_a
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Dec 05, 2009 | KitchenAid KERC607 Electric Kitchen Range
Mar 28, 2008 | KitchenAid KERC607 Electric Kitchen Range
Oven elements dont work / stove top works fine
I just had a repairman fix my Kitchenaid 507KERCYAL0 electric range and oven. The problem was a $4.00 fuse. I didn't see exactly what he did but he accessed the fuse from the rear - had to pull out the range and I think remove a panel. Hopefully this helps and saves you $$. I ended up paying $90 to fix a $4 problem
Nov 28, 2007 | KitchenAid KERC507 Electric Kitchen Range
All Surface elements are dead
Sounds like you might have a bad oven surface control board also called power board. The part # is 316239400. It is located on the left hand side about mid way down on the back of the oven. First, disconnect power and make sure all connections on board are tight. Plug back in and make sure you have power to that board if possible with a meter. If all check ok then the board is bad.
Oct 05, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC308LSS Electric Kitchen Range Logo
265 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
