Question about Car Audio & Video
SDCard and USB won't play video
When I insert an SDcard or USB thumbstick into the player, nothing happens. Occasionally I get a flash of the file menu display and then back to the standard "no disc" image. Do the SDcard or thumbdrive need to be formatted to a particular file storage type (NTFS or FAT32) or is there a particular MP4 format that I need to use? I converted these files from AVI to MP4 using Any Video Converter using standard MP4 video setting. The resulting MP4 files play just fine on my computer but file system menu does not even display on the Power Acoustik player.
  • armydog13
    armydog13 Dec 09, 2012
    Additionally, perhaps a MicroSD card will not work. Does it have to be a Full Size SDcard?
    Master:
  • 604 Answers
Format them first,then when you finish adding files to them,finish it like it would be a cd/dvd
Posted on Apr 27, 2017
4 Suggested Answers
  • 9 Answers
SOURCE: Sony Walkman Video NWZ-S616F
it only suports MPEG-4 AVC format im looking for a converter as well currently because im having the same problem
Posted on May 20, 2008
SOURCE: mp4 player
try this link...perhaps it can solve ur problem...
http://www.quantum-optimum.com/firmware-f.html
You're welcome,...
Posted on Jan 10, 2009
SOURCE: Video File Format Error
Here are instructions for how to put the videos on your v-touch.
http://www.visual-land.com/vtouchfaq.html
Posted on Mar 11, 2009
How do I use my SD card for internal storage?
There are a quite a few options.
  1. Open Terminal Emulator and check with the 'df' command, how much space is left on your partitions. Is /data or /system full?
  2. Goto system/apps/all > 'Sort by size to' find out which apps eat
    up the most space.
  3. Check if you have big size apps installed where you could change data location within the app to sdcard. Thinking of navigation apps and games. Every app where you have to download additional data to the actual app.
  4. Make sure you use the sdcard for media like photos (camera settings) music and video.
  5. CM has a built-in system to move apps to SD under settings/apps/on sdcard. Check apps that are big and you use rarely and are not interactive first. Reason: If you still use the USB feature those moved apps are not available to system anymore and are least likely to cause trouble.
  6. Another option is to use the app Foldermount. Use it to move certain locations to SD like the Download folder. Or the DCIM folder if the camera doesn't support sdcard location in settings.
  7. Use the app Link2SD which is able to move every bit from an app (including app data) to SD. It has a good overview on how much space an app really needs. You will have to create a separate partition on the SD card for that to work.
Mar 20, 2015 | Tablets & eReaders
HOW TOGET NEW TONES IN SDCARD
You can't use SDCARD for CTK810 model.
Please connect to a computer using a USB cable. Then you can use a commercial MIDI file player to play to your keyboard.
Alternatively, you can download SMF Converter from
http://music.casio.com/e/smf/
This program will convert SMF (.mid files) into a format readable by your Casio keyboard and then load it directly into your keyboard.
May 03, 2014 | Casio CTK810 61 Key Keyboard
I put a sdcard in the mp3 player & it still won't hold a charge or save pictures that I take, why?
If you charge the MP3 player using the USB cable and the battery will not charge up then the battery is worn out and needs replacing.
Jan 01, 2013 | Audio Players & Recorders
My HTC g1 is having issues reading my 16gig class 4 sandisk micro sdcard. It worked for a while but after saving a little over 1 gig of files it just stops working properly. I am running cyanogenmod 6.1 ds...
click start control panel administrative tools computer management disk management right click on your sd card select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
Right click on sd card select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your sd card select properties then on customize restore Default in W 7
hope this helps
Jun 14, 2012 | Electronics - Others
I Have purchased a AVH P3250,, i cannot play any videos by a usb or even by an ipod, what do i do? and do we need some special cable to play a video through an ipod??? Please Help!!
I've checked out some specs for you, this item cannot play video from an iPod apparently. It will play DivX encoded videos from CD/DVD/USB/SDcard. it will play it will also play dvd's or Video CD. i think the video in these is a wrapper that includes MPEG4 video and some kind of audio. You might be able to play .avi files for example.
Cheers
Moza805
Aug 30, 2011 | Televison & Video
When I try to put music on the micro sdcard I cant.Then I try format the sdcard and it tells me the sdcard is write protected.
Hello!!
I suppose you are using the card via inserting it in the CAP ( Holder) that came with the card to be able to make it used with card reader.
So, the Micro SD card gets locked only through it's CAP (Holder)
Steps to Unlock :
Insert the card into the CAP (Holder).
Please check the Upper Left side of the CAP (Holder).
There must be One switch which will slide Up and Down.
Push that switch to Upper side. (Pushing to downward will lock while the reverse will Unlock the Card).
Now Insert it to Card Reader to use it.
Hope it Helps..!!!
Jul 06, 2011 | Samsung Propel SGH-a767 Cell Phone
My mini sd card is in raw format - how do i change it back to fat
Below is a link to an SD Formatter provided by sdcard.org. I have used it in the past and it has worked well.
http://www.sdcard.org/consumers/formatter/
Sep 21, 2009 | Electronics - Others
Get album art on g1
To do this you're going to have to re-copy all of the music you want album art for to your G1! Sorry! But here goes...
Firstly, the reason the album art isn't there is because it wasn't bought online, therefore the album art may not be encoded onto the songs. However it's not that hard to encode art yourself on Windows Media Player.
You have to look for the album art online, and save it on your computer. Then, find the songs you want on Windows Media Player (if they are from the same album then ctrl+click them all) then right click. On the right-click menu there should be an option called Advanced Tag Editor. Click that, then the Pictures Tab, and click Add. Then find your album art and select Cover (Front) from the Picture Type drop down menu. Hopefully that will encode your songs with the album art, then you can sync them with WMP or copy and paste them as normal.
Apr 05, 2009 | HTC G1
I pluged in my HTC Touch Pro and i can find it on my computer
This is because your Touch Pro is not a Mass Storage device. You have to actually take out the memory card and put the memory card into the Memory Card Adapter and place the adapter into your computer in the memory card slot. You then have to label folders for MUSIC, VIDEO, IMAGES, and DOCUMENTS and then place the files in the corresponding folders. It will make that noise because a USB device is being connected. This device can be used as a modem which is why your computer recognizes it.
Dec 13, 2008 | HTC Touch Pro Smartphone
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
