SOURCE: Not cooling
Replace the defrost timer about $20-30.00. One plug 2 screws. Mine was located on the bottom front behind the grill. (model HMG 24922) . Follow startup directions.
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
SOURCE: GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
SOURCE: Stopped cooling but i can hear running
The overload/relay is probably bad .This is the part plugged onto the compressor , with 2 or 3 wires plugged onto it . You can easily replace this part . Be sure to have your model number when ordering .
SOURCE: I have a Jenn-Air side by side frig. The freezer
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
