Goodman GMP050-3 furnace With thermostat in of position and auto fan it will start the blower motor once in a while and blow cold airand then shut off.
With a new thermostat installed the furnace will run the blower fan once in a while with the thermostat set in the off position and blower on auto. Would this be a bad board?
  • vjbegger
    vjbegger Dec 11, 2012
    I have a Goodman furnace model GMP050-3 that turns the blower motor on when the thermosat is in the off position and the fan switch set on auto. After it runs awhile it shuts off and and later it will start up again.
Therinnaiguy
  • 1420 Answers
SOURCE: furnace won't stay running
1 FLASH
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
sensor.
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
induced draft blower
performance.
• Locate and correct gas
interruption.
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
igniter.
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
termination.
• Verify proper induced
draft blower performance.
Posted on Nov 25, 2008
  • 85 Answers
SOURCE: Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Posted on Dec 09, 2008
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
  • 89 Answers
SOURCE: GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Posted on Oct 08, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Ihave a goodman GMPN furnace. The blower will not
Maybe not! there is a limit switch that has opened not allowing power to pass and start the furnace. You will need to tale a Ohm meter and follow the wires thru any safety switch. In your case, it may be the thermo-disc near or over the burner box. Jump it out to test it. Now why is your blower not working (which could have been the reason why the thermo-disc opened)? Once you find which safety switch is open and you have jumped it out, take a jumper wire and jump between the R and G terminals on the circuit board. This should start your fan. If not, either the fan is stuck, the fan motor is bad or hopefully noy; the circuit board is bad.
Posted on Jan 18, 2010
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Furnance running all the time never shuts off
Turn the thermostats fan position to Auto instead of ON. If it already is in Auto, then there is a fan relay stuck in the board.
Dec 13, 2013 | Goodman Manufacturing Goodman AEPF313716...
Furnace blower runs after temp is reached
Is your tstat fan selector in auto?? Does the fan ever shut off?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 18, 2017 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
I have a goodman furnace model number gms80904bncc. When the temperature in house is met the blower continues to blow. Even if I put the thermstat in off mode the blower is still on
Hi #1 check thermostat : see if the FAN ON/AUTO switch is set to( auto ) and not( on)...If this is not the case turn the furnace switch off for 20 sec. and back on...did it stop? IF so the blower relay is sticking and must be replaced.
AUTO=BLOWER ON DEMAND/CYCLING
ON=BLOWER 24/7 all the time..
hope this helps
Nov 15, 2011 | Goodman Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
The furnace send signal to the fan in about 30 seconds, now this fan is set in auto from my termostat, my problem is the fan is starting slowly and some time it don't start, but if I use the option manual...
Depending on the model of the furnace, the blower is either a 2 or 3 speed. When the furnace operates in heating mode with the thermostat in the auto position, the furnace starts the fan when the furnace reaches a specific temperature or after a set time delay, but it operates the fan in low or med low speed on heat mode, when you put the thermostat fan switch in the "ON" position, the furnace operates the fan in "HI" speed, the same speed used for cooling mode. You may have a blower moter that is starting to short. I would recommend having a professional replace the motor before now before it becomes an emergency in the middle of the night during a cold spell.
Oct 10, 2009 | Heating & Cooling
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
