Question about Dryers
I can't find the fuse in my dryer. Is it a buss fuse? Can I get the fuse at any hardware store?
Unless you see a fuse on a wiring diagram-- there are none
I have never seen any on an electric dryer
Posted on Dec 09, 2012
Fuse rating for plug for wirlpool awz3303
30 amp tandem breaker or 2-30 amp cartridge or "Buss" screw-in plug fuses as this is the top amperage required for any household dryer rated up to 5,000 watts
Dec 18, 2010 | Whirlpool Dryers
Will not turn on
There are buss fuses inside. Most likely one or 2 are blown. There are 5-6 screws in the bottom(4 corners and 2 in the middle) that are in deep holes. these hold the cover on. The other screws on the surface are for various mechanisms, and should not be removed. Turn it over, lift off the cover (leave the cord attached, after unplugging it..). The fuses were right on top for my 3000 AF. Replacements may be available at an auto parts or hardware store. The type is usually marked on the cap on the end (voltage and amperage). You should check for any frayed or loose wires that caused it to blow, but sometimes, with age, heat, shock (dropped it?) they go out.
Sep 28, 2010 | Vivitar V5000AF Slide Projector
The fuse for the heat keeps blowing but dryer runs
if its an old round buss fuse that screws in the panel(especially an old 60 amp panel),sometimes the center where the fuse lands the insulation gets weak in this area and lets it arc over when the dryer calls for current to heat the element replace this with a sub box and breaker set-up.the other thing it can be is the element is touching the units case and grounding out causing the same problem
Jan 25, 2010 | Kenmore 82822 Electric Dryer
No sound: The receiver has suddenly stopped giving out any sound, regardless on which input I use. Have tried powering off/on (disconnecting all power), and checked front-speakers on another receiver.
That sounds like you blew the fuses inside the receiver. Take the cover off and check them. Typically thats the problem and if I'm not mistaken they are AGC-5 Buss fuses available at your local hardware store.
Aug 10, 2009 | Yamaha RX-V663 Receiver
New dryer keep blowing 30 amp fuses
your problem (especially if you are using screw-in "plug fuses") i.e. BUSS fuses and cartridge fuses they get hot and with time the insulating disc that insulates hot from neutral (grnd) breaks down and with dryer current draw it arcs over and in summer its more humid which contributes to moisture,have a new sub(pony) panel if you have no room for another 240volt circuit in your main panel,that should cure your trouble
Jul 19, 2009 | LG DLE5955 Dryer
What type of fuse do you get for a Breeze AT EcoQuest unit?
A buss type fuse is like the glass tubeb with metal ends and just snaps in two clamp type holder. Any automotive store carries them. know what amperage, like 5, 10,15 ,20 etc. The 250 v is the norm. The fuse protects against amperage overload not voltage. They come in tins of assorted or specifc in fives. Good luck
Jun 21, 2009 | Ecoquest Breeze AT Living Air Purifier
89 f-150 no power to fuel pump
If it takes buying a set of fuses (which it might not even be a normal/buss fuse anyways), then I think it's worth it.
Most autoparts stores will help you out with locating where the part goes.
Jun 19, 2009 | 1989 Ford F 150
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Fuse blue in the car adapter and at the same time garmin 300 nuvi went dead and wont start up with either car power or battery power.
Blue fuses are usually 5 amps.
Red ones, 10.
Yellow, 20.
The fuse inside a cigarette adapter is usually a 1A, buss fuse - available from Radio Shack or "The Source By Circuit City".
If your blue fuse blew, then visit your nearest department store, and purchase a new fuse. Buy a box of 5 or so just in case.
Sep 17, 2008 | Garmin GPS
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
