Question about Candy Refrigerators
Cfmf 235 as-80
Fridge on constant fast freeze
2 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: candy futura cfmf 266a fridge freezer problem
Either the thermostat is set to high or you need to replace the thermostat.adjust it to 1/2 way position position and if temp is to cold and it doesnt want to switch off, it means the thermostat is faulty.
Posted on May 21, 2010
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Crystal cold lpg fridge the fridge part works fine but the freezer only cools to the same temp as the fride compartment
The freezer should go down to about zero degrees. If your unit is constantly running it is because the internal temp has not activated the thermostat to turn off the compressor. Lower than normal refrigerant levels could account for this. Also to be checked out is the evaporator coil not being frozen over with a block of ice - the latter is caused by an inoperable self defroster - this causes the freezer to not cool properly and raise all internal temps.
If not a self defrosting unit, defrost the unit and restart unit. It will cool properly until the evaporator freezes up again. How fast it freezes up depends on how often the freezer door is opened and how much moist warm air enters the freezer compartment.
Nov 21, 2013 | Refrigerators
Hotpoint rla31 motor constantly running/freezing at the back
Your fridge is cooled by the freezer, the thermostat is within the Fridge to tell it to shut off, you might have a bad fan or a build up of frost where the air is sent to the fridge, check where air goes to the fridge when it's running, if you don't feel air flow then something is up, best thing you can do is take everything out and allow the fridge to defrost, at leat 24hrs. then see what happens, if you don't feel air flow after the defrost then you fan is shot and you'll need to replace it.
Aug 04, 2012 | Hotpoint RLA31 Compact Refrigerator
Candy futura cfmf 266a fridge freezer problem
May 21, 2010 | Candy CPCA240FFK Bottom Freezer...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hi, I've got a candy fridge/freezer combi. (bottom freezer) It's a futura CFMF 236a. Fridge compartment is freezing everything. got solid milk, solid drinks and frozen food. When the fan cuts in it just...
The super is for super cold and on that setting it might not cut off. If it's not on that setting then that control is probably bad.
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
Refrigerator-
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
Feb 10, 2010 | Refrigerators
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
Scandinova fridge freezer. Fridge works, but the lower freezer section only freezes when on fast freeze. Any ideas? We live in Australia but the unit was purchased in the UK. Do you know in which country...
When on fast freeze the freezer thermostat is by-passed and current sent directly to cooling gas compressor. I suggest the freezer thermostat is knackered, fitting a new one isn't too difficult, that is if you can get your hands on one out there !!!!
Unfortunately I don't know where Scandinova are made, or more to the point IF they are still in production but, some replica spares are to be had.
Good luck.
Oct 30, 2008 | Refrigerators
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
My LG GRL207QVJA fridge is freezing everything. Changing the temperature setting on the front control panel seems to make no difference & the temperature in the bottom half of the fridge is constantly at...
I would check your owners manual but most LG only have a 12 month warranty .
check your Express or Fast Freezing Function is not turn on.
then you most like have a Thermistor/ control problem.
let me know
Apr 05, 2008 | Refrigerators
Refrigerators Logo
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
