Question about Sennheiser Mm400 Bluetooth Headset
Sennheiser bluetooth headset not working on Win7x64
I'm using this BT dongle: http://dx.com/p/mini-bluetooth-v3-0-usb-2-0-dongle-71248 Windows detect the BT radio and install default MS drviers when i "add a device" it detects MM400 headset but no driver is found. Sennheiser doesnt privide Windows drivers at all.
SOURCE: Sennheiser PC 30 Headset not recognized on vista
My friend...
The sollution f this problem is to downliad this firware...install it and your headphones will be redy to play!!!
http://www.senncom.com/comm/icm_eng.nsf/root/support_faqs_pcusb_ms_vista
Posted on Jan 12, 2009
  • 2427 Answers
SOURCE: I have purchased a BW900
in windows xp!!!
click start
all programs
accessories
entertainment
volume control
click devices
recording devices
check the box for your default device..
Vista / Windows 7
right click the speaker icon to the bottom right of your screen (tl bar)
click recording devices.
click set as default,, you may also adjust and set up the device..
Posted on Mar 16, 2010
casouzaj
  • 1118 Answers
SOURCE: Sennheiser VMX100 Bluetooth Headset
In order to pair it with your phone, it must be in pairing mode first. If it has never been paired to another device before, just by opening the boom, the indicator light should flash alternately in red and blue, thus indicating it is in pairing mode. Otherwise, to force it to go into pairing mode, press and hold the volume (either + or -) whist opening the boom. It should flash alternately in red and blue. Only then, make the other device's b'luetooth application search for new devices. After a while, the VMX100 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful. Now, ot pair it with the other device (the VMX100 is able to pair to up to 4 different devices), make sure the previous device has its bluetooth radio turned off. Then, repeat the pairing process with the other device.
Hope you are able to sort your problems out soon.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Posted on Nov 05, 2010
  • 22 Answers
SOURCE: Connection bluetooth between MM400 and Sony VAIO
I dont owe one.
Posted on Feb 01, 2011
  • 16 Answers
SOURCE: I have bluetooth headset MM100
This is a strange question I will explain.
The MM100 is working according the A2DP (bluetooth) protocol.
So windows 7 can not find your sennheiser drivers because there are none.
Windows 7 needs the driver for your bluetooth card. This is either integrated in your computer or you are using a USB dongle.
Through the bluetooth software within windows 7 or a alternate program provided with your bluetooth card you can look for your sennheiser. This is colled pairing.
There are thousends of methods to pair so read the manual of your computer (bluetoothcard or dongle) aswell as the MM100.
Good Luck
Posted on Aug 03, 2011
Bt211 not detecting devices
kindly check your hardware its working on not check by hardware detaction tools downlode by google ,& check hardware name .& driver version .
Aug 30, 2017 | ASUS USB-BT211 Mini Bluetooth Dongle -...
Enable blue tooth for EM2501915
Product Model records for that system show it does not have a bluetooth module built in.
I use this in my netbook:
http://www.dealextreme.com/p/ultra-mini-bluetooth-2-1-edr-usb-2-0-dongle-37665
Works great with Windows 7 and it's incredibly small.
Jul 18, 2012 | eMachines eM250-1915 Netbook
Manhattan BLUETOOTH DONGLE, USB, MINI CLASS2+EDR (179218) Network Adapter
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
to suit multiple usb devices
ยท Operating system: Windows 95/98/2000/XP/2003/NT/XP 32-bit/AMD 64-bit/2003 32-bit/AMD 64-bit
hope this helps
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don't use numbers and / - you might have to try a few times to get it right
hope it helps
May 13, 2012 | Manhattan BLUETOOTH DONGLE, USB, MINI...
How can i activate pre-installed webcam in my dell inspiron mini 1012
Step 1: First connect the bluetooth device to USB port on your computer and check that it is detecting on your computer or not.
Step 2: Now insert the bluetooth software driver CD to your system that will auto start after few seconds then follow instruction to finish bluetooth software installation.
Step 3: Now go to 'start -> Devices and Printers' and click 'Add a device' from top of the window.
Step 4: Now your Windows 7 system will search the bluetooth device which connected to your system.
Step 5: Click the bluetooth device you want to install from the list and then click the 'Next' button and wait for windows to configure the bluetooth device. If prompted to enter a passcode, enter the default code listed in the bluetooth device manual. In many cases, the default passcode will be '0000'.
Now the bluetooth device has successfully installed and ready to use.
Note: If you bluetooth device was not listed in the search results from Step 4, make the device discoverable. Access your Bluetooth-enabled device's settings page, and turn on the device's 'Listen' or 'Discoverable' function to allow you computer to find it.
Feel free to get Dell technical assistance anytime at http://www.vtechsquad.com/dell-support/
Apr 10, 2012 | Dell Inspiron Mini 1012 Netbook...
Draiver for msi(ms-6970) compatible for windows7
Hey there, get the latest drivers for the Bluetooth adapter for the ms-6970 MOBO here:
http://www.laptop-software.com/compaq-drivers/msi-btoes-ms-6970-bluetooth-usb-dongle-windows-driver/
Have fun :)
Aug 15, 2011 | MSI ms-6970 Bluetooth Wireless Adapter
I have Acer 5730 laptop. I installed Windows XP professional SP3. I installed all the driver except wifi & bluetooth. Can you assist me in this regards?
Both of these driver's can be obtained from http://www.laptop-software.com/acer-software/acer-aspire-5730-5730g-5730z-5730zg-driver-and-software/
If your laptop has Bluetooth capability, there will be a white sticker on the bottom with the Bluetooth logo. Some models have a switch that must be turned on to activate it. If your laptop doesn't have Bluetooth built in, you can purchase an adapter that plugs into your USB. I use http://www.dealextreme.com/p/mini-bluetooth-v3-0-usb-2-0-dongle-71248, it's about $5 with free shipping and I've never had any issues with it on my Dell.
Aug 04, 2011 | Computers & Internet
Need a driver for a Tiny USB 2.0 bluetooth EDR dongle mini wireless adapter, can you help me locate the driver Mike
These dont need drivers on VISTA or windows 7
However in some instances under XP you may need to give it a nudge
This is done by going to the DEVICE manager and selecting the device then under DRIVER select UPDATE DRIVER.
I have a few of these in various flavours. Also you may want to take a look at "bluesoliel"
It is a very nice BT application that makes using and connecting BT devices a breeze
http://www.bluesoleil.com/
Jan 30, 2011 | Tiny Computers Tiny USB 2.0 Bluetooth V2.0...
Connect to internet?
This answer assumes that the reader is already using their SD slot and wish to use another way to connect to the internet. I'm going to show you how to connect a USB Bluetooth dongle using the Toshiba e350 USB host cable. After that you can choose to share a computer internet connection via ActiveSync/WMDC or use BT DUN and a wireless phone with existing internet plan.
Windows based PC software (only needed for ActiveSync based internet sharing):
ActiveSync or WMDC
Toshiba PC Bluetooth stack 7.10.04 (or latest version for your operating system, I'm using Windows 7)
PC Hardware:
Super Mini Bluetooth 2.0 Adapter Dongle (mine was VID 0A12 PID 0001 Broadcom BCM2045 "CSR" based)
WM2003 PPC software:
Zeno USB Host Drivers v6.0a
Toshiba PDA Bluetooth stack 4.01 (filename bltstk-401-en.zip)
WM2003 registry editor (TaskMgrv2.9_WM2003SE.zip is a free task manager and registry editor, very cool)
Opera Mobile 8.65 (optional)
WM2003 PPC Hardware:
Toshiba USB host cable
2 or 4Gig SD card (for e350)
I'm going to target a Windows 7 PC with USB Bluetooth adapter, Windows Mobile Device Cener (WMDC), and an already partnered and synced Toshiba e350/355. The reader should already have a 2Gig SD card in the e350; remember WM2003 doesn't support SDHC. Any software to be installed onto the device should be done through ActiveSync Add/Remove and should not be installed to the default internal memory, but instead to the SD card.
Let's start by loading the e350 software. Install the Zeno Host drivers, followed by the Toshiba 4.01 stack. There is a newer version of this stack but it didn't work for me, so find the older bltstk-401-en.zip. The registry editor is needed for ActiveSync internet connection sharing but optional for BlueTooth Dial-up Networking (BT DUN). I'd recommend installing Opera Mobile as well. Be sure to press the reset button on the back of the e350 when done. You may now connect the USB host cable with Bluetooth adapter.
On the Windows PC connect your Bluetooth adapter and install the Toshiba PC bluetooth stack. Power up the e350 and, after a short time, there should be a wireless icon in the lower right hand corner of the main window. Back to the Windows PC, double click the Bluetooth icon in the task tray and you should be prompted to create a new connection. After awhile it should recognize your Pocket PC. If at any time you are prompted to insert a password for secure connectivity, write down a number (preferably 8 or more digits) and type it in. It will probably ask on the Windows PC first but once you continue immediately check your e350 since it will now prompt for the same password. Once it has been entered in both devices they are now "paired".
Tap the wireless icon on Pocket PC then Bluetooth Settings. Tap the magnifying glass to search for connections, your PC should already be listed as a remote device. Tap and hold over the name of your PC in the upper portion of the window and select Update Service. At least one COM port should be listed in the lower window. Tap and hold over it's name, then tap connection registration.
On the Windows PC open WMDC and select Connection Settings. Change the "Allow connections to one of the following:" drop down to the COM port listed on your device and be sure it's checked. The other settings should be default.
On the Pocket PC tap ok to close Bluetooth settings then tap Start > Programs > Bluetooth Folder > Bluetooth Connection. This will initiate an ActiveSync session and, if everything has gone well, it should connect, perform a sync then immediately disconnect. I have a problem with the immediately disconnect part, that's where the registry editor comes in. Using your preferred registry editor locate the HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\Bluetooth\DeviceProperty\Mode\ActiveSync\AutoDisconnect key. It's default value shoule be 1 but we want to change it to 0 thereby preventing ActiveSync from disconnecting after it sucessfully syncs.
With that done you'll probably need to reset the e350 again. At this point, because ActiveSync is set to share the computer internet connection by default, the next time you connect you should have internet access. Open your preferred web browser and check. When you are done with the internet, tap Start > ActiveSync and the Stop button. In Windows 7 as long as I'm connected I can see the Pocket PC in Windows Explorer as if it were an external drive. This makes it very easy to copy files back and forth wirelessly. Initially I set up a bridged PAN connection but, to be honest, ActiveSync works much better all around.
For BT DUN you'll need a properly configured and enabled Cell Phone with bluetooth DUN capabilities. Simply make the phone "visible" and search for it as you did the Windows PC. Pair with the phone, Update Service and register Dial-Up Networking. Tap Start > Settings > Connections tab > Connections > Add a new modem connection (Tasks tab). Enter a name for the connection and choose Bluetooth Card as the modem, then set the dial-up number, User Name, and Password from your Cell Provider. On the Advanced tab (next to Tasks tab) you may want to tap Select Networks to verify "Programs that automatically connect to the Internet should connect using:" My ISP.
You can set up ActiveSync Internet sharing along side BT DUN. When ActiveSync is connected it will automatically be the source internet connection. When disconnected, the e350 will automatically attempt to use the BT DUN connection instead.
Why not use the default Microsoft BT stack on the PC? It doesn't publish any real services, just a COM port that I never got to work. The Toshiba BT stack does have a 30 day warning so you might need to fix that.
For me the total cost of setup was about $30. The host cable was $15, the SD card $10, and the USB BT dongles were $2 apiece.
Nov 03, 2009 | Toshiba e350 Pocket PC
Acer aspire 4730z bluetooth problem
Yes your Machine got WPAN: Bluetooth® 2.0+EDR (Enhanced Data Rate).
If its not working then you need the drivers, you can download them free here
If you problem was solved, Kindly do Rate!
Jul 31, 2009 | Sony MEX-BT2500 CD Player
Driver for bluetooth for win 98
Hi!
1 Was it working before?
2. Is the bluetooth compatible with Win98? Does it meet the bluetooth's minimum requirements?
3. Is your computer an old computer? Maybe your computer's USB ports are USB 1.0 and the 4Gb USB is USB2.0. This I believe will be incompatibile.
4. Try those USB adapters at a different computer to further isolate your problem.
Hope these info helps!
May 01, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
Sennheiser Mm400 Bluetooth Headset Logo
577 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
