Question about Refrigerators
I have a kenmore elite side by side refrigerator coldspot model 50599003. It is leaking water from somewhere underneath..I was.told it could be a water valve..It is not leaking from the supply line connections.
  • Refrigerators Master
  • 4,655 Answers
Are there 3 numbers missing in that model number? Something is missing in that model number somewhere. This could be several possibilities causing the water leak. A defrost condensate pan may have a crack or the union just behind the kick plate going to the dispenser from bottom of refrigerator may be leaking. Or this could be the result of a defrost drain blockage inside the freezer having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
The model number should be like this=> 321.236589 Let me know if you can because that number is not coming up, Thanks Sea Breeze
Posted on Dec 10, 2012
  • 172 Answers
SOURCE: kenmore coldspot - How do you remove the ice maker box to clean
Hi Cincygrl,
Well lets see, I believe you have a whirlpool made kenmore, Your model numer should start with 106.
The problem you are having is from our drain. When you freezer defrosts the water should drain down a tube and under the refrigerator into a pan. If the tube gets clogged it will leak water into the freshfood section. To clear the drain you will need to remove everything from the freezer and remove the inside back panel in the freezer. in the center bottom under the coils and the heater you will see a tiny hole. That is your drain. If it is frozen over you will need to defrost the ice or you may need to run a smaller tube into it to clear it of an obstruction. I use a small rubber hose and I just insert it into the hole and blow on the other end. If you have something in it, it should blow out. If it does not then it may have ice in it and you can pour hot water into the drain and defrost it. Once clear you should not have any further problems. But they do make a drain heater probe to keep ice from forming inside the drain. You can get one for about $6.00. Good luck and I hope this helped you. mca0824@aol.com
Posted on Apr 30, 2008
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
weblord
  • 507 Answers
SOURCE: I have a Kenmore Coldspot
try this diagrams as well
or try this:
Product questions
Call 1-888-KENMORE (1-888-536-6673).
Posted on Nov 05, 2008
SOURCE: kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Posted on Dec 22, 2009
SOURCE: Kenmore Elite - bottom Freezer - water leak from refrigerator
Found this solution on another site. http://davesgarden.com/community/forums/p.php?pid=6759829
Posted on Jun 25, 2010
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Water leak from my Kenmore Coldspot Frig Model 106. 59792990
U have a restriction in drain tube under evaporator coil. So every time it goes into a defrost instead of going down the drain tube it is running over and out the front of fridge
Mar 08, 2013 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
Not cooling
condenser must be burnt
Jan 19, 2012 | Kenmore Side by Side Refrigerator
I have a kenmore elite refrigerator about 10 years old, side by side model 50599003, still blows air but both frig and freezer are blowing warm are. condensor?
Check for clogged condensor coils underneath rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 16, 2011 | Refrigerators
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Water Leak
do you have a water dispensor?? is there ice in the bottom of the freezer??
Oct 02, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
