Question about Panasonic TC-P50X1 50 in. Plasma HDTV
Panasonic plasma power button problem
Problem getting power button to come on. Same with the remote. Have to play with it for a while to get it to come on. Once it is on it is fine, but you don't want to turn it off. Takes forever to get it to come on again.
  • ANGELA MASON Dec 09, 2012
    It is ONE Blink but I hadn't been able to find anything for just one blink. I had read about updating with the SD card but he had already taken the thing apart and that just seemed to simple. Thank you, Thank you, Thank you!!!
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Have you looked for bad filter caps on main power board?
panasonic plasma power button problem - 12_10_2012_3_41_21_pm.jpg12_10_2012_3_41_41_pm.jpg
Posted on Dec 10, 2012
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
dsacco86
  • 1077 Answers
SOURCE: Panasonic Viera 46" plasma~no sound, no picture
I would use the warranty at Bestbuy at that point. Opening up the TV would most likely void the warranty.
Posted on Jun 28, 2009
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
ekcnoel
  • 998 Answers
SOURCE: I have a panasonic 50 inch plasma th-50pz80u.
try to check power supply look for swollen capacitor it is the common trouble of plasma and lcd.
Posted on Oct 15, 2010
Where is the power button on Panasonic 50" plasma
The "power button", which may be identified merely with a symbol usually is located at the top of the universal remote although some place the power button near the bottom.
Jan 05, 2014 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Continuous blinking light on Panasonic Plasma
had the same problem wih my panasonic, it was a faulty power switch. make sure the power switch is sitting centrally in its housing, if not you may need a new switch
Jan 02, 2014 | Panasonic TC-P58V10 Plasma TV
My 32" plasma TV (ikon)
My 32" IKON Plasma TV not getting on. when press power button on remote LED on TV getting bling only
Kindly Help
Abdul Rasheed
Dec 27, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Cannot get the closed captioning to go away on my panasonic viera plasma.
Look for button marked STTL on the tv remote. Not the remote that came with the dvd or home theatre. The actual TV remote.
Aug 30, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
My panasonic viera plasma TH-42PX80U will not come on. tried plugging tv directly into wall, no go. someone somewhere suggested holding power button down for 10 seconds, did that. no response with remote,...
Hi:
You will need to count the number of red led blinks on the power indicator, if it is at least 10 then replace the power supply it is faulty, In my years of servicing panasonic Plasma, power supply failure is about the most common failue in this class of television from this manufacture.
Aug 24, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TV won't fill screen when playing video
The remote has a button on it marked pic size,aspect or zoom. You may be able to access it the through the menu button on the set. You can download the operation manual from the Panasonic web site. You can also order the remote from that site.
Oct 31, 2009 | Panasonic TH-37PHD8UK 37 in. Plasma...
No screen saver
depending on your tv there is a function to turn screen off. most tvs come with this feature. on the remote there will be an power key with a red or black button. this is to turn the screen off. if it does not have this function and there is no screen saver setting on the dvd play there is not much you can do for this situation .
Jul 05, 2017 | Panasonic DVD-S97 DVD Player
Panasonic TC-P50X1 50 in. Plasma HDTV Logo
186 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
