Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Rope snapped in my recoil starter..
I have a Tecumseh LH318SA Snow Thrower. Went to start it and pulled the handle, heard a snap and the handle and rope came out. Is there any easy way to fix this? I have easy access and can remove the cover to the recoil starter but I have heard nightmare stories about springs popping out ect.
Any helpful hints?
Thanks,
Snowed In, West Roxbury MA
  • 1 more comment
  • Tiller D Mar 08, 2009
    Thanks for the start! However, when I tried to rewind the spring as you suggest, apparently the inside end of the spring had come loose (?) and I could hear it "click" with every revolution so it never wound up. Further access seems to be to uncrimp the axle, pull the cover of and see what's what()?) I get the sinking feeling, I'm in for a $50 replacement of the whole thing and down time just when I'm doing spring tilling (Troy Built, Econohorse, 6hp Tecumseh) - what do you suggest?
  • JERRY ABELL
    JERRY ABELL Jan 21, 2012
    hello joy,,you can remove the 3 small screws holding the pull stsrt on 1/4 ", i don't know if the pull ring is rivited on or has a bolt in the middle,if rivited on you have to buy a new one,if there is a bolt in the middle you can get a new spring and install it,when you remove the ring make note on how it comes appart and put back together,the price for a new pull start is aroung $60.00,,hope this helps.
  • JERRY ABELL
    i was wrong the pull stsrt is $80.00..
    Problem Solver:
  • 8 Answers
Take off the and and turn the coiler on the inside a few turns and when it starts to get tight put a screwdrive through it so it wont spin, put the rope in the hole and bring it out and tie a knot. the turn it gently to release the screwdriver and let it coil the rope back in
Posted on Jan 22, 2013
  • allstarcyr
    allstarcyr Jan 22, 2013
    take off the and and turn the coiler on the inside a few turns and when it starts to get tight put a screwdrive through it so it wont spin, put the rope in the hole and bring it out and tie a knot. the turn it gently to release the screwdriver and let it coil the rope back in
Tecumseh lh318sa auger does not work
If you are asking about the pull cord and when you pull it the engine does not turn and the cord pulls super easy it generally means that the dogs inside the cove assembly are not engaging. This may be caused by a broken spring or dog inside the pull cord assembly. You would need to carefully remove the assembly cover from the engine and pull the cord to see if the dogs are protruding from the assembly if not you would need to repair or replace the parts as needed if so then you would have to check if the will still extend under strain, if not then repair if they still protrude under strain you would have to examine the engine where the unit was removed and look for damage or wear and replace parts accordingly. If you are in fact asking about the front or snow auger on the snow blower itself then the most likely answer would be that you have sheared a pin which holds the auger to the shaft that rotates it. The shear pins (as they are called) are designed with softer metal to break if you hit a large piece of ice, stick or rock that may damage more important and expensive parts of the blower if they stayed intact during the incident. To fix this merely find the hole in the auger along the shaft that is no longer pinned (the auger should spin freely) spin it to line up with the hole n the shaft (which may still have a broken piece of the shear pin in it) drive out any remaining pin with a punch and replace with the appropriate pin for your machine. If the pins are intact you may have a bad belt, pulley, or tensioner and you would have to move further into the repair process.
Feb 16, 2015 | Tecumseh Snowblower Snow Blower Starter...
Electric start on craftsman 9 hp snow thrower won't start engine it sound like it's turning but engine won't start. I can start engine with the pull rope. Started last week with the electric start.
Sounds like you need to replace the gear drive on the starter. If the starter turns but the engine is not turning you have starter problems.
Jan 22, 2015 | Garden
Yard machine snow blower
be sure to check in blower housing (the round part) that impeller isnt frozen at the bottom
can also take off belt guard (2bolts) and check to be sure belts are on correctly
Dec 18, 2013 | Yard Machines 28" Two-Stage Snowthrower
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Continuity testing a 34443A solid state iginition
Hello, the only way i test the coil is unplug the ground wire and remove the plug,use a spark checker.pull the rope if no spark than coil is bad,hope this helps..
Jan 22, 2012 | Tecumseh Snowblower Snow Blower Starter...
When I went to start my craftsman model 247.88704 snow thrower, the pull handle rope came out. Can you tell me the best easy to put it back together?
on your pull rope housing youll find 3 to 4 bolts remove the housing inside youll find the place were the rope was tied in [ if it just came untied ] just rember to spin counter clock wise for your tinshion befor replaceing the rope then put back together
Feb 10, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Recoil rope won't recoil!
-In bnjays case the rope was broken. Sometimes the rope retracks partially or slowly because the surface that the spring edges rub against when retracting the cord, are badly rusted. Disassemble and wire brush the rust off, or leave assembled and spray in thru holes in the pull start with WD40.Avoid getting WD40 on the rope.
Feb 18, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
932 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
