How do I reboot a toshiba estudio 3510c copier
I just replaced the system board and the hard drive on a toshiba estudio 3510c copier. I turned the machine on and ir says " Unmutched update file please reboot the machine" How do i reboot?
  • john Dec 09, 2012
    I shut the power off and turned it back on several times but the messege keeps coming back. what could I do?
  • john Dec 11, 2012
    I put in the new Hard Drive and system Board but the Copier will not start. keeps saying " Unmutch update Files"
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
  • 53 Answers
SOURCE: Turn Off Power Save Toshiba eStudio 150
Don't know if this applies to Toshiba but Xerox machines have the same annoying problem, which is NOT fixable.Xerox machines are used in the EEC who insist that power save is not resettable only able to be set to 120mins max Gotta save the power y'know!
Posted on Jul 19, 2008
  • 643 Answers
SOURCE: I want reset my estudio 163
Press *+1+3 and power on the machine.
Posted on Feb 13, 2009
hi how do solve this problem system error E007
Posted on Apr 09, 2009
SOURCE: i have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
Posted on May 25, 2009
Location hard drive estudio 3500
open the back door and yo will see harddisk is connected with system board
Mar 30, 2014 | Toshiba E-Studio 3511 Color Copier
How to reset cdfo error toshiba estudio 355se
CDF0 Offset tray related
service call
Initialization error of the offset tray: The home position of
the separator cannot be detected when the power is
turned ON.
[CDF0] Initialize error of the offset tray (e-STUDIO205L/255/305)
(1) Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
(2) Check if each connector between the OCT board (CN261) and LGC board (CN302) is
disconnected.
(3) Check if each connector pin is removed or the harness is broken.
(4) Check if any conductor pattern on the OCT board and LGC board is short circuited or open
circuited.
(5) Replace the OCT motor.
(6) Replace the OCT board.
(7) Replace the LGC board.
Oct 31, 2013 | Toshiba e-Studio 350 Copier
How do you print #10 envelopes on the Toshiba Studio 3510c?
http://www.copiers.toshiba.com/usa/support/training/index.html
Oct 15, 2012 | Toshiba E-studio 3510c Color Copier....
Remove hard drive from estudio 450
Pull off the back cover, then the metal cover that has the two wire fan plug going in to it. The hard drive is under there.
TOSHIBA PARTS AND SUPPLIES
Sep 04, 2012 | Toshiba Office Equipment & Supplies
I have a Toshiba EStudio 3511. It is giving a message saying Service Required. I hit clear and number 8 and I get error code F070. How do I fix this? I tried turning it off and on several times even from...
f070 communication error between system cpu and main cpu
firstly try updating the firmware version
then possibly replace the system board and or lgc board good luck
Mar 23, 2011 | Toshiba E-STUDIO 850 Copier
Problem with code F11 on Estudio 311c - aspanner
[F11] Communications error between system-CPU and scanner-CPU
This quite often can be cleared up by resetting the machine. If not you will want to check all of the connections between the scanner, the scanner board and the system boards in the back of the machine. If nothing is loose this is likely a very critical error and you will need to have a toshiba authorized technician take a look at your copier.
Sep 08, 2010 | Toshiba COPIERS - E-STUDIO 311C Copier
Toshiba 3510c , error code cd70
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Aug 11, 2009 | Toshiba E-STUDIO 650 Copier
Toshiba Copier eStudio 232 malfunction
i face same problem and by replacing main board my problem was solved
.check by replacing main board.or is any code appears by pressing start key .
Dec 14, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba eStudio 211c
it is hard disk trouble. First enter in service mode (pressing 08 while turn on the power) next, type 690 and set to 2, click enter and wait the "reboot the machine" message, then turn off and on again
Apr 11, 2007 | Toshiba E-STUDIO 211C Copier
238 people viewed this question
jasbo
jasbo
