Question about Canon ZR500 Mini DV Digital Camcorder
Canon ZR-500 wont charge
I plug the charger adapter into the camera and the red "charging" light turns on yet hours (im talking like 20 hours even) later the red light is still on and when i unplug it, there is still no power. I was told to replace the battery, which i did yet the same problem still occurs. do i need a new chager? and is the charger just the adapter the plugs from the wall straight into the camera? thanks
  • Anonymous Apr 01, 2009
    Same thing. No matter how long charger is attached to camera it does not charge battery. Red light blinks every second constantly which suggests it is not charging (I think stays red or blinks much faster when charged). I have tried with about 3 new batteries so it is not battery pack.
    I have a feeling we need a new charger.
5 Suggested Answers
SOURCE: Canon mv940 camrecorder won't power up even with charged battery
My friend went back to England and got it sorted there
Thanks
a
Posted on Jan 22, 2009
drifterK
  • 4924 Answers
SOURCE: My Canon ZR60 has developed
The issue with all cameras is that it discharge the batteries even when it is turned off..so it is recommended to take the batteries out when you not using it for a while ..This way the batteries will keep the charge ...If they are discharged for good than it will not turn on even with the charger plugged until the batteries are charged a while ..and if the charging has place with the camera off it will not turn on until the charging is made or until the charger is removed after charging a while ..
Posted on Feb 12, 2011
Rick Riggins
  • 1812 Answers
SOURCE: no power to Canon ZR500 I Have No Power g in Canon
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Jun 22, 2011
Rick Riggins
  • 1812 Answers
SOURCE: I have a canon ntsc
Posted on Jul 21, 2011
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Canon zr 200 camcorder won't turn on unless plug into electrical outlet.
Hi, Please charge your battery ( with camcoder Off) for at least 1 hour. Then unplug your charger and turn On your camcoder. If it can not turn on, it is apparently you have flat battery and need replacement.
Dec 03, 2010 | Canon ZR200 Mini DV Digital Camcorder
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
Wont charge
There are 2 possible reasons. Charger is incompatible/defective or Battery is no longer charging due to its 500 cycles life. You may check the output of the charger with Voltmeter/Multimeter if its stable 5V, If its stable then best thing to replace the battery.
Good Luck
Jun 11, 2009 | Kyocera Finecam SL300R Digital Camera
It wont charge when i plug it in or will any lights come on nothing happens at all
The S210 is a camera, not a battery charger. In order to charge the battery, remove it from the camera and insert it into the supplied battery charger.
May 01, 2009 | Nikon Coolpix S210 Digital Camera
My jvc camcorder GZ-MG37U will not charge
Camcorder has charging circuit but it could go defective. The repair would be costly so in this situation, you can purchase stand-along battery charger for around $20 and charge the batteries independently. Make sure all the contacts are cleaned and camcorder is working with direct ac adapter. Good luck -James. for furnter assistance by email, go to www.camerarepairjapan.com
Feb 11, 2009 | Canon XL2 Mini DV Digital Camcorder
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
NV3 Camera - won't turn on or charge
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Jun 24, 2008 | Samsung NV3 Digital Camera
Canon ZR500 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
