Question about Hitachi Televison & Video
My tv has horizontal lines and displays no ref signal
There was "no" picture.. i replaced upper and lower bufferboards. the upper board had one burnt chip out of 8.. it now has picture upon power-up but has horizontal lines top to bottom and displays "no ref signal".after 40 secs or so it displays "power saving" and then shuts off. i suspect the y sustain board ???????
  • Hitachi Master
  • 8,617 Answers
Yesthe sustain board should be replaced when the Buffers are replaced especially if the old buffer had a shrted drive IC as that usually damages the Y sus board also.
Posted on Dec 09, 2012
5 Suggested Answers
  • 910 Answers
SOURCE: At first it was no
Have you replaced both the Y Driver & Y Sustain Boads?
Posted on Jul 19, 2011
jdvillanueva
  • 2098 Answers
SOURCE: Original problem, Working great when
Yes, you should replaced the Y scan board. I saw your board on Shopjimmy.com but before you ordered it online, check the part no. of your board on the white sticker. Replaced also all filter electrolytic capacitors in the output of the power supply feeding the Y-sustain board.
Watch the video below for more info regarding electrolytic capacitor.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Sep 04, 2011
SD Tech
  • 14553 Answers
SOURCE: Panasonic TC-P42C2 Horizontal Lines in Picture
problem could also be inside the display panel.
Posted on Jun 08, 2012
  • 115 Answers
SOURCE: Hi, I'm working on a Philips 42PF7220A Plasma TV that came in dead. I replaced the y sustain board and now it has thin black horizontal lines 1/4
change x card to
Posted on Oct 09, 2012
Blue power light flashing on and off, but no picture
check for puffed up capacitors on main board usually 3300/100v bigger ones on board replace and then check buffer boards upper and lower for blown chips if so replace
Aug 10, 2013 | Hitachi P50H401 50 in. Plasma HDTV
Has sound but, no picture
could be digi-main or BUFFERS (Drivers) ON SDR Upper and/or Lower PWBs (50"~60") holes in chips must look at them good.
Jan 18, 2011 | Hitachi P50H401 50 in. Plasma HDTV
DELL PLASMA
Most cases the Y-SUS, Y upper buffer, and Y lower buffer is the problem. The replace the 3 boards are located on the left side of the chassis when you open up the TV. 90% of the time this will solve the problem.
Look for burn marks on the upper and lower buffer boards (mostly around the chips with the heatsinks on them).
Apr 01, 2010 | Dell W4201C 42 in. Plasma HDTV
No picture, just sound, blown y buffer board twice1
a4.. there are 2 of them, upper and lower buffer boards.. they control the top and lower half of screen devided horizontally, i have had many run ins with these sets. and usually the buffer boards arent cheap.
they plug into the ysus( y sustain).. its possible your y sustain is blowing the buffer moduals because one of its i.c.'s under the heatsink has popped on ya.. effectively creating a short that blows the buffer boards.
remove the buffer boards, turn tv on... feel the 2 silver heat sinks on that y sustain( beware dont zap urself.. just the tip of your finger on the heatsinks)
you may find that one is cold and one is hot...if so, you need a new y sus and probably to replace the buffer boards the a4 upper and a4 lower.
If you get a new ysus.. plug the a4 upper and lowers into it, look at your picture.. if ur missing the top half the top buffer is blown or lower half the bottom buffer is blown. or..no picture they could both be blown..an easy way to tell if u have no picture to diagnose is..touch the heatsinks that sit over the chips on the buffers..if they are red hot.. they are bad and shorted internally.
Dec 05, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Convergence is off in the lower right and upper left corner
The repair isn't too complicated if you're comfortable working with a soldering iron. Sounds like one of the "guns" is shot. The chips that need replacing are attached to the heatsink on the convergence board. The reason for replacing both chips is if you're going to bother to take the board out and replace one bad chip, that is the best time to replace the other older chip. The link below is to step by step instructions including pictures of the repair. You can check it out to see if you want to try it. If not, the repair is expensive (between 250-400) depending on the repairman. Best of luck with your convergence problem.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
May 23, 2009 | Toshiba 50A61 50" Rear Projection...
Hitachi 55PD9700 sound no picture
upper y scan board had a blown chip. removed board and lower screen lit up. ordered a new upper y scan board.problem solved.
May 16, 2009 | Sylvania Televison & Video
I have a Phillips Magnavox Model number 42PF9936D/37. A red pixel looking 2" X 7" rectangle has appeared on the plasma screen and can be seen underneath the image. How can I fix this?
We chatted previously, remember to reseat the cables that go to the section of the screen that is distorted. The Y drive boards will be on the left side of the tv (when viewed from back) and there will be about 8 ribbon cables hooking these board to the plasma panel. If you can, look at each square black chip on the board. Each chip drives the picture (row - horizontally) so one chip may be blown causing your issue. It will likely have a small pin sized hole burned in it if bad. You can replace the corresponding board (upper y, lower y) to fix the issue. Hopefully reseating the cables will do it, for a part free fix. Let me know when you get the TV open and I'll assist more. Thanks again!
Dec 09, 2008 | Televison & Video
Unable to resolve concave issues
I am also having the same problem. I tried to replace ICs but no luck. I am also looking for service manual in case if some one can give it to me.
Thanks,
Sanjay
Jun 24, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
