Question about Tyan Toledo I3210w S5211g2nr Lga775 Xeon Intel 3210 Raid V 2gbe Atx Server Motherboard
I am getting a BIOS POST error (87h) from system start to O.S. desktop
I have this problem from the time that i assembled the system with all default settings with 8gb (maximum memory) Kingston KVR667d2n5/2g x4 and INTEL CORE-2-DUO processor, 2#WDC5003abyx in RAID 1 format with 2#LG "DualLayer Sata Optical Drives w/Lightscribe with no graphics card no sound card with a Netgear WG111v2 network adapter with a XION-xon-600f-14r-201 PSU I also called Tyan Computer Support Mr Steven Thompson and he told me that the Motherboard is EOL and would require a $75 repair fee to configure and repair with a 10 day waiting period for the service.
  • 1 more comment
  • John J Vella
    John J Vella Dec 14, 2012
    I am sorry to say that the solution to My BIOS POST ERROR 87h did not solve my problem and made the problem worse, Firstly the entry you mentioned was not in system services and when I restarted the system i could not boot into the operating system for the RAID 5FORMAT was completely deleted and I could not reactivate the raid function anymore.
  • Brian Sullivan
    Brian Sullivan Dec 14, 2012
    Which operating system ? It could not have made the problem worse you where only doing a search not interferring with any settings
  • John J Vella
    The O.S is Microsoft Windows 7 Ultimate 64bit SP1
  • Tyan Master
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
if you need more help with this post a reply with the error message details so that someone might be able to provide a solution
Hope it helps.
Posted on Dec 10, 2012
System options not set hp compaq dc 7600
Make sure your clear cmos jumper is not in the clear position! It is usually close to the battery and there is labelling on the mboard near it. If you're sure you didn't move it, then don't worry about that.Did you try setting the bios to defaults?
One possibility - it could be it does this if you don't re-set at least the date (and possibly the time) in the bios from the default it sets itself to when you remove the battery or use clear cmos - set it to today's date and time, or to anything other than the default, save settings.
If after you save the above settings, turn off the computer for a few minutes, and check the bios again, the date and time re-sets to defaults, then the cmos doesn't see the battery. If the date and time are consistant with what you set them to, it is seeing the battery.
By the way, I don't think this is the problem because you have the 162 error code, but make sure the battery polarity is right - is in the holder the right way - and the contacts for it are making good contact - if it is the wrong way or the contacts are poor, the cmos will think there is no battery. Usually you can tell by the way the contacts are arranged which way it goes - if it is the wrong way both contacts touch the same part of the coin cell (if that is what you have) - usually + is upwards.
If setting the bios to defaults, setting the date (to anything other than the default) does not get rid of the error message, try making sure everything on the board is properly seated. Unplug the computer when you do that!
.........it says memory error, below that it says 162 System Options not set, then it says 164 error.
(later)
I just took everything that would unplug and reset them in and it corrected the problem. Thanks
That error code is common on many computers, and in many bioses.
e.g.
161 POST Error - System options not set - (Run SETUP) - battery
162 POST Error - System options not set - (Run SETUP)
161 System options not set; dead battery
162 System options not set; CMOS checksum/configuration error
If it is 161 the battery is dead, it is installed with the polarity backwards, or the battery contacts are not making good contact.
If it is 162, there is nothing wrong with the battery - you need to go into the bios Setup.
I have found nothing other than the above post about what to do about that.
If you still have issues, go to and talk to one of our techs
Clean Optimize Speed Up and Secure PC Freeware Download EZ System Repairs
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Oct 15, 2015 | HP Compaq dc7600 Small Form Factor PC...
Tip
BIOS error, System Failure, Boot failure? ? Lets FIX it.
I guess everyone working on a computer is familiar with the word BIOS and what exactly it is? Still let me tell that BIOS is intelligent software that enables the system to start. I need not to mention that system here refers to computer. Bios facilitate the booting of a system without human intervention. BIOS is a program that is installed in a hardware chip known as ROM chip.
This single word matters a lot to most of the users who face various problems when their system failed to start normally or make some unusual activities. Each time I visit any technical forum I see a lot many users posting their problem regarding BIOS. I researched on internet about BIOS errors and from my knowledge and experience I am posting this piece of help for those who find themselves helpless in getting a solution to BIOS problems.
Sometimes BIOS itself provide a troubleshooting to most of the problems. When you power ON your system it give beep sound. Checkout some beep codes
1 short Beep indicates System is OK (Acceptance Beep)
Continue long Beep tells RAM Problem
1Long 3 Short Beep confirms RAM Problem
2/3/4 short Beep --its time to Check the RAM & Video Card
By now most of you have found some clue about the problems you are facing. Now learn about POST faults
1) K/B Error/ NO Keyboard present
· Check the loose cable connector
· Cable may be bad (Keyboard)
· K/B itself may be bad
· Check the physical condition of K/B connector on M/B
· If all these are ok & problem is still processed
· Than replace the keyboard port
2) Floppy disk drive Fail
· loose data & power connector of FDD
· Data cable may be bad (FDD)
· Load the CMOS defaults
· Floppy disk drive itself may be bad
3) CMOS Checksum error
· CMOS battery has gone bad replace it. (Weak)
· Check the CMOS jumper it may set on clear
· If the entire ok than check the CMOS battery jack, it may be bad
4) Invalid System Disk, Insert System Disk & Press enter when ready/ NTLDR is Missing
· Check the root directory; it may be formatted or missing bootable files.
· Repair the Windows or Reinstall the operating system.
5) Disk Boot failure, Insert System Disk & Press enter when ready
· Hard Disk check in POST Detected or not
· If not Detected Check the power cable
· Check the Master/Slave jumper setting.
· Also check BIOS setting
6) Computer gives message: Your computer has a serious problem
Back up your data & replace your Hard Disk
This error message is displayed due to the SMART option. This scans the HDD for errors, if it detect the errors than it show the above message. Follow the error message & back up your data on to another drive.
I tried to explain most of the problems along with their solutions. There could be a lot more solutions for the problems. Make your own search and try to fix BIOS problems at your own home.
Forward this to all those who need help!!
SOVI
on Feb 09, 2011 | Computers & Internet
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
Unable to enter Asus 6850 BIOS
I would start by resetting your bios settings to default; turn off your system, remove the side cover and gently pry out the board battery (round "button battery" such as cr2032). Leave it out for about one minute, and reinstall. Then see if you get a post screen.
Dec 29, 2013 | ASUS Computers & Internet
Locked out from eee box 1035 need to reset bios how?
Try this. Right out of the manual. The reset button is the little pin hole next to the power. Will need a paper clip that is straightened.
Entering the BIOS Setup
BIOS (Basic Input and Output System) stores system hardware
settings that are needed for system startup in the PC.
In normal circumstances, the default BIOS settings apply to most
conditions to ensure optimal performance. Do not change the
default BIOS settings except in the following circumstances:
An error message appears on the screen during the system
bootup and requests you to run the BIOS Setup.
You have installed a new system component that requires further
BIOS settings or update.
WARNING!
Inappropriate BIOS settings may result to instability
or boot failure. We strongly recommend that you change the BIOS
settings only with the help of a trained service personnel.
Quickly enter the BIOS
Windows8 boot time is quite fast, so we developed the following
three ways for you to quickly access the BIOS:
Before booting up the system, insert a straightened paper clip
into the BIOS Reset key.
BIOS Reset key
Press the power button for at least four seconds to shut down
your PC, then press the power button again to turn your PC back
on, and press F2 during POSt.
When your PC is off, disconnect the power cord from your PC's
power connector. Reconnect the power cord and press the
power button to turn on your PC. Press F2 during POST.
Oct 16, 2013 | Compaq Presario 5000 PC Desktop
I have a message manufacturing mode:level (67)
Do the following with nothing attached other then the AC Power. After trying these fixes and neither works, it is a mother board issue. Replace the mother board.
1. Enter System Setup (aka BIOS) reset it to its default settings. By doing the following:
Sep 11, 2010 | Dell Latitude D610 Notebook
I need to set the bios admin password old one forgotten
You have to unplug the power cable, open the desktop's caseand locate on the motherboard a small round battery like that
Remove the battery and try 3-4 times to power up the system (with the power cable unplugged) for the capacitors to discharge. Wait some minutes. Put the battery back at it's case. Plug the power cable back. Start the system and get into bios settings, locate the "load bios default" and do it. Set up the rest settings (date, time, boot order e.t.c.) as you wish. Save and reboot.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 10, 2010 | Dell Computers & Internet
I forgot the master BIOS password. IBM thinkpad 2628. There`s no start possible. Additional I get several error information: Error 271 Ceck date and time settings Error 251 System CMOS checksumbad- default...
disconnect the intal cmos battery, there may be a jumper near by, j1 or something like unconnect the jumper, whilst the cmos battery is disconnected switch on the laptop, then let the post screen load, switch off, re-connect the cmos battery and re-enable the jumper, switch on, should work fine now, if you don't see the jumper, you won't be able to reset the bios password, refer to a service manual for your laptop model for the location of j1.
Apr 04, 2010 | IBM ThinkPad A21m 2628 Notebook
When i start my 300pl desk top system. when i
Hello my friend.That error message has nothing to do with the actual keyboard.The POST/BIOS is reading a single port bit in the system boards keyboard controller and detecting this bit as being shorted to ground. On some systems there is a keylock on the front of the case that allows you to "lock" the keyboard for security reasons. It is this lock that is being detected. On a system without a keylock, this error can be caused by one of the front panel wires being placed on the wrong pin on the system board. Or by something shorting out the keylock pin on the system board, or a hardware failure in the keyboard controller, or using the wrong version of BIOS.So make sure if your computer has a lock key/button or something on the case that locks the keyboard.Also you can load default bios settings by hitting Del while you boot if you have change anything in the bios.
Feb 08, 2010 | IBM 300PL (PC 300 PL 733) PC Desktop
Beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
Standard Original IBM POST Error Codes
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
May 25, 2009 | Dell Dimension 4600 PC Desktop
Tyan Toledo I3210w S5211g2nr Lga775 Xeon Intel 3210 Raid V 2gbe Atx Server Motherboard Logo
59 people viewed this question
Top Tyan Computers & Internet Experts
Larry Chandler
Andrew Taylor
Andrew Taylor
Robert Graf
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
