Question about Radio Communications
CB MIcrophone RewireJob. A Diesel Model 360-100 to cobra's
Hi, I need a synopsys for wiring a Diesel Microphone model 360-100 ,5 wire microphone to Cobra/Galaxy 4- pin radio hookup. Wiring on the Mic is 1-yellow, 2-black, 3-white, 4-black, 5-red. What goes on Cobra/Galaxy #1, #2, #3, #4 ? I'm LOST.
Does it have a sheld wire?
Posted on Jan 14, 2009
I have a none amplified D104 G stand it came off my TRAM D201 IT has a two center leeds that's shielded I know this will work on my cobra 29LTD but I don't get it please help
First, you have to replace the cable as you will need a minimum of 4 wires, 2 of them for the transmit and receive switching, and a shielded cable for the audio. It would be nice to have another as the common for the TX/RX switching but the shield is commonly used for this.
You will need to re-wire the switch in the candlestick to allow switching from RX to TX.
Google "D104 to cobra 29 mic wiring" and you will find many hits for this.
Your microphone was not intended to work with this style of radio. To save a buck, the CB manufacturers removed a 50 cent relay to do the transmit/receive switching. You can see what happens when you remove the microphone when you are listening to the Cobra. It'll stop producing any sound. This won't happen with the Tram,
Also, you may have problems with the microphone as it is high impedance as indicated by no transformer or preamp in the base of the microphone. This may be a problem as the Cobra has a relatively low impedance input.
Aug 07, 2016 | Cobra Radio Communications
How to wire a 4 pin ProComm microphone to work on a 5 pin microphone for a Uniden Grant XL
The simplest way is to order a microphone adapter from ebay or a reputable CB shop. I have all my mics wired for standard 4 pin cobra. The standard 4 pin cobra is the most common and if you keep adapters handy then you can use all different kinds of mics on different radios.
Apr 09, 2016 | Uniden Radio Communications
I want to wire my superstar dm452 power echo mic to my realistic trc 465 am ssb and need to know what color goes to what pin?
its a 5 pin which all radshack radios are and they are all,99% anyway, wired the same . So take an old radshak mic apart at the plug and see how it is wired then experiment from there.
Apr 07, 2015 | Workman Publishing Workman DM-452-5 model...
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
Nov 23, 2009 | Cobra 29 LTD CB Radio
Wiring problem on Cobra HG-M75 CB Mic
Pin-1-Shield-Ground
2-Yellow-Audio
3-Red-TX
4-Black-RX
notes:The blue & white wire not used.
Jul 03, 2009 | Cobra HG-M75 Microphone
No Transmitting, no RX sound, but can hear speaker click on...
Hi there!!
The symptom sounds like a bad Microphone connection or a bad microphone!! The Cobra has a built in circuit that wont allow you to hear anyone until the microphone is plugged in and the no transmit part will also do the same. Try another microphone that is wired right for that radio before you do anything else!! let me know!!
Dennis
Mar 18, 2009 | Cobra 29 NW CB Radio
Astatic noise canceling microphone to 4 pin cobra 29 ltd classic
According to the astatic wiring hand book it is not used. I would leave it terminated but long enough that if you find your having noise when you receive you could still ground it. I'm pretty sure you don't need it.
Goodluck
Rob
Nov 02, 2008 | Astatic 636L Noise Canceling Microphone...
Radio Communications Logo
441 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
