Need help adjusting the screen size on a Sony Trinitron KV-32FS13
Help! The picture is larger than the screen so all four edges are cut off. I have the user manual but there doesn't seem to be a way to adjust or move the image on the television screen.
  • kjenkins80 Jan 13, 2009
    Sorry, could you please explain what the yolk is?
  • seanstu Feb 22, 2009
    The picture seems too large for the tv screen, as if zoomed in. Miss out on telephone numbers, titles or other items displayed. Tried adjusting the wide angle etc to no avail.
    Problem Solver:
  • 12 Answers
Try to adjust the yolk away from the picture tube
Posted on Jan 13, 2009
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The Tv screen is much smaller during video games than what it is during Movies. Please Tell me how to adjust my screen size.
Movies are shown at a higher resolution than games. That is why the picture is smaller with games than movies. If you turn the Auto Picture Size off, you can set lower grade video to a larger screen size but you will lose quality.
Hope that helps.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is cut off on sides but not top and bottom. The display channel (default 2) is cut off on the side to give you an idea. (purchased it new around 1998-1999).
With TV powered off, use remote control to successively hit DISPLAY, 5, sound volume +, and POWER all within a second of each other. This takes you to the Service Adjust Mode and the first thing that appears is the Horizontal Size Adjustment "HSIZ". Press numbers 3 or 6 to make the picture larger or smaller. Other things can be adjusted by using numbers 1 or 4 to go through the list but you could really screw up your TV so don't do anything unless you are sure about it. When you're finished hit MUTING and then ENTER to save the changes.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
May 13, 2009 | Sony Televison & Video
Sony Trinitron, no picture, sound works fine.
There are potentially dangerous high voltages present inside the set even when unplugged, so caution is required. That being said, if you can solder, you may be able to resolve this. If the picture returns with movement, it is possible that the problem is poor solder connections. Try removing the back and sliding out the main board. Resolder any connections that appear grasiny or have rings. That may resolve the problem.
Keep us posted.
Feb 03, 2009 | Sony KV-32FS13 TV
Sony 36" trinitron
check the horizontal output of your tv sets,if shorts need to replace it.
Jan 11, 2009 | Sony KV-32FS13 TV
Sony kv-32fs13 chirps and flashes
Hello 0279737,
This problem is caused by a shorted Horizontal Output Transistor. I would suggest that you have this TV checked by a qualified TV technician. This type of problem requires dealing with dangerous voltages, and repair should only be attempted by a trained technician.
I hope this helps
Thank you,
Oct 28, 2008 | Sony KV-32FS13 TV
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Setup codes for a sony kv-20fs12
i have sony kv 14 gmr1mk r2ks always shorted and the other 1 appear like a lightning in midle of screen.. kv 21gmr1mk when adjust the brigth and contras it shut down the picture and blinking..can u help me how to troubleshoot this problem? what remedy you sudgest..thank you...
May 03, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
946 people viewed this question
Top Televison & Video Experts
