Question about Trek 4300 Disc
Skipping when applying pressure to pedals - Trek 4300 Disc
  • 73 Answers
Your gears are not synced. Simply log onto shimano.com and look at their help and maintenance section for very good diy video.
Posted on Feb 20, 2015
    Problem Solver:
Needs a gear adjustment hopefully. it might have a stretched chain along with worn cassette teeth. if you have ridden alot of miles in the smaller gears in the rear you might have worn them out. you would have to replace chain and rear sprockets/cassette
Posted on Nov 12, 2013
08 ram 1500 two wheel drive 4.7 flex fuel extreme bouncing when braking, the truck is smooth as silk at any speed until applying brakes (at any speed) you better hold your drink
things to check
if discs -check for good disc surfaces --not cracked or missing
if drums check for cracks or out of round
if solid front axle check for loose worn spring mounts / shackle bushes
if independent suspension check for suspension/ball joints
check for failed shockies
this affect is achieved when the brakes are applied and the wheels stop turning b and the axles are allowed to rotate in the suspension
when that rotation is arrested then the wheels skip on the road and again twist the axles
if it has abs breaking then run the fault codes as it may be faulty and not controlling the brake pressure as set by the foot pedal
Oct 01, 2015 | Cars & Trucks
Brake lights 98z71.New brake switch,but when brakes applied switch doesn't activate.I can apply pressure on switch and press pedal i then have brake lights.Y won't switch engade pressing pedal?
try adjusting the switch away from the pedal as it requires to be free when the pedal is moved so that the contacts in the switch can activate and turn on the lights.
Sep 03, 2015 | Cars & Trucks
Brake lights wont work when pressure is applied
brake switch needs adjustment if it works with slight pressure on the pedal readjust it where it needs to be..
Feb 09, 2013 | 1999 GMC Yukon
My power conditioner will not power my cry baby, unless i apply pressure to the 9v adapter on the wah.
If you mean applying pressure to the power connector on the pedal, a COMMON problem is that the soldering of the connector inside has broken loose or there is a crack in the circuit board inside. Open pedal and inspect for these problems.
Mar 20, 2011 | Dunlop Crybaby 9v Ac Adapter W/5.5mm Tip...
1997 Probe Gt, 5 speed, 2.5 L V-6; 77,750 miles: replaced clutch master cylinder 11/15/2010. Clutch free play okay, pressure to push clutch pedal down- okay (these conditions apply to vehicle after...
THe problem can only really be with the clutch master cylinder. What you describe sounds like the master cylinder is not relieving pressure and this is building up in the salve cylinder, applying pressure to the pressure place and causing the clutch to slip. Can you make the problem go away even temporarily, if you open the bleed screw on the slave cylinder? You say that the free play is correct, but is the master cylinder returning fully to its released position?
Jan 26, 2011 | Ford Probe Cars & Trucks
Jukebox makes records skip.
Most skip problems are caused by a worn stylus or not enough pressure being applied to the stylus. This being caused by the weight on the end on the tone arm being off place.
Jun 20, 2010 | Audio Players & Recorders
1998 Buick Century Low Trac light comes on and car skips.
have you bled the brakes? If you have, you may need to do it again as there sounds like there's an air lock in your lines.
Mar 14, 2010 | 1998 Buick Century
Noisy engine
hallo
if black smoke from exhaust follows accelator pedal check preasure (rubber) hoses from turbo charger to intercooller to engine for leeaks and/or cracks.
marko
Sep 23, 2009 | Ford Escort Cars & Trucks
Hi have xbox 360 and 3 lights are flashing it was freezing up now havbe the lights the code is 0013
I am looking for adjusting instructions on a Falcon Index System. I know this is not a expensive kind but it skips or seems to slep when trying to apply pedal pressure in any gear.
Jul 24, 2009 | Microsoft Xbox 360 Console
Intermittently I need to press harder to get the brakes to work.
sounds like your master cylinder is beginning to internally bypass. By releasing and re-applying the pedal you are essentially "pumping" the pedal, to regain pressure. A quick check is to apply moderate pressure to the pedal and hold it. If the pedal begins to sink, replace the master.
Also check everything for small leaks that slowly bleed system of fluid and permit air to enter. (especially wheel cylinders and backside of master cyl.)
Jul 16, 2009 | 1997 Honda Civic
Trek 4300 Disc Logo
105 people viewed this question
Top Trek Cycling Experts
John Egan
John Egan
Mark Schmit
Mark Schmit
Are you a Trek Cycling Expert? Answer questions, earn points and help others
