White horizontal lines covering picture on Toshiba 51HC85
I have a Toshiba 51HC85. It worked completely fine until now. The problem started not too long ago with the tv taking half an hour to warm up. Until it warmed up there were white horizontal lines going all across the screen. When it was warmed up completely, the lines just disappeared.... Until the next time you tried to turn the tv on. We began to leave the tv on 24/7 so we wouldn't have to deal with waiting for the picture to clear. We recently rearranged our room, having to unplug and move the tv. Now the problem is much worse. No matter how long we keep the tv on to warm up, the lines never go away. Sometimes they fade out so you can vaguely see the picture on the screen but most of the time you can't tell anything that's being shown. Any idea what the problem is? Or what it would cost to be fixed?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The set uses a Hyper board inside that processes all signals, it is well known for this issue, board no longer available=reason is quite simple : about a dozen tiny surface mounted filter caps on that board with age dry out, at first it will work after warms up as poor caps regain some capacitance and seem to be ok.
Buy a new set, you can send that board out and have it repaired/rebuilt but the last one I saw which was under extended warranty cost about 200 just for the board rebuild.
In the last 4 years Here on Fixya I have encountered only 2 people who were able with instructions had the skill to remove the board and replace those caps, both were top notch computer repair techs.
Posted on Dec 10, 2012
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Blurry Picture on Toshiba 65HX81
yes the tv has convergence problem u will need a tech to reposition it
Jul 11, 2013 | Toshiba 65HX81 65" Rear Projection...
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
    I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
    Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
    My picture turns into a white line and comes back if you hit the front bottom of console?
    I think you flyback transformer is going out. Eventually it won't come back when you hit it.
    Oct 30, 2009 | Toshiba 32A33 32" TV
    Sony KP-51WS510
    you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
    Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
    Poor picture quality
    You need to consider the following tips herein as follow:
    1) Field collapse (horizontal white line on screen)
    R710 dry joints. Same as C2146TN & C2546TN problem solved with thanks to Mike G & Barty. Power off/unplug. Get to circuit board underside with aerial socket up-R710 is near top and right of centre-cluster of 4 joints best resoldered
    2) Picture is horizontally narrowed and deformed
    Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
    Please let me know any update
    Nov 29, 2007 | Toshiba 27AF42 27" TV
    32 in RCA MODEL NUMBER f32650
    TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
    Sep 11, 2007 | RCA F32650 32" TV
    Thin horizontal line across picture
    I really dont understand the problem Could we see a picture of this please?
    Jun 14, 2006 | Toshiba 35A44 35" TV
    Televison & Video Logo
    173 people viewed this question
    Top Televison & Video Experts
