Question about Exercise & Fitness
Nordictrack c1750 firmware stuck in checking for updates?
I just unpacked and assembled the treadmill. Trying to update firmware as recommended. It has been saying "checking for updates" for the past 2 hours. How do I stop this process or get it to actually update?
    Top Expert:
  • 12,223 Answers
Reset the machine, see the button in the instr. manual and proceed according.
God bless you
Posted on Dec 13, 2012
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 9 Answers
SOURCE: Nordictrack treadmill C2100 belk is not slipping
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
Posted on Oct 22, 2009
  • 40 Answers
SOURCE: I have the Nordictrack Apex 4100I treadmill. It
try caibrating it.
maxtreadmill
  • 832 Answers
SOURCE: My treadmill is stuck in the max incline position
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Jun 11, 2010
  • 218 Answers
SOURCE: My Nordictrack treadmill seems to
it is trying to calibrate itself, let it go the whole way up and then down without interrupting it. Then it should be fine.
Posted on Aug 11, 2010
Why is device activation code not working for hulu plus?
The TV probably needs a firmware update. They are needed frequently, and if not up-to-date you will get problems like that. Using the menu system, select "update." Note: They do not recommend updating via wireless because if anything goes wrong with the connection, your system is toast. Best bet is to download the update via computer onto a USB drive, then insert the usb drive into the TV (it may have a specific USB location for updates; check manual), and during the update process you will be asked whether to update via internet connection or USB drive. Select USB drive for "location" of update. (Go to Vizio web site, enter model number, and download the latest Firmware Update for your TV. NOTE: Do not do _anything_ with the TV during the update process... wait until after it says "complete.")
Jan 14, 2016 | Vizio L32 32 in. LCD HDTV
Update failed internal error 12000
How are you loading this update? Via usb or burned disk? It may be an ISO file that may need to be unpacked first. Try reformatting your USB using a FAT 32 table. Then unpack the ISO onto the USB and insert it into your TV. Make sure the TV is off, then insert then turn it on.
Jan 12, 2012 | Vizio VBR231 Blu-Ray Player
My creative Zen MX is permanently locked and none f the keys function. Restting the machine does not help - on switching it on again it reverts to the same state.I can't activate the "yes" key in...
Have you tried updating the firmware of your Zen Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
Before returning the player, try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZM+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update.
Mar 30, 2011 | Audio Players & Recorders
How do i update the firmware for the VP8870? Ive already downloaded the zip file. All my video files suddenly disappeared! Anyone know why?
While performing firmware update all data will be erased !
See the manual on page 36:
Vosonic VP8870 manual
The firmware update for the player is PMP.VP8870-1.0.0.B2.mtg :
Since you've downloaded the zip file, were you able to unpack it with
Winzip op Winrar ?
When using XP you can unpack by:
1. [Right click on the zip file] Open with > Compressed maps [left click on Compressed maps]
2. The next screen shows the opened zip file. On the left side the
folder task manager can be opened ( Folders / Maps in the top bar not selected): "Unzip all files" : follow up the Windows unzip wizard and
remember the location of the files.
How to do the firmware update is explained in the pdf file "How to update 1.0.0-B2 - VP8870 .pdf", added to the firmware update in the
zip file.
Remember:
Sep 12, 2009 | Vosonic Audio Players & Recorders
Us 144 firmware not updating with Lepord
Try going to Add/Remove software and removing tascam software. Then, unpack your new drivers.
Nov 27, 2008 | Tascam US-144 Sound Card
Froozen
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Apr 22, 2008 | Creative Labs ZEN V Plus MP3 Player
FROOZEN
try downloading the
Will not play
try downloading the
Jan 20, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Mp3 player
try downloading the
Sep 27, 2007 | Creative Labs Zen Touch MP3 Player
Froze, battery wore, charged it, n still wont come on
try downloading the
Aug 01, 2007 | Creative Labs Zen Touch MP3 Player
Exercise & Fitness Logo
710 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
