Olivia 42" LCD TV won't go on
Will not turn on
  • 8,617 Answers
If its dead then i would suggest replacing the power board. But need more info and also model number to assist you further.
Posted on Dec 09, 2012
  • 92 Answers
SOURCE: olivia 42'' flat screen and cant get any cabel channels
make sure that you're not using a cable box. then when you do the channel scan, make sure that you pick cable instead of antena.
Posted on Jun 18, 2009
SOURCE: 42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Posted on Mar 17, 2010
  • 56 Answers
SOURCE: My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
Posted on May 18, 2011
ronaldo_ross
  • 1056 Answers
SOURCE: My son dropped my 32'' inch LG lcd tv now it won't
It probably has a cracked circuit board. If you want to repair it on your own open it up and see if you can find where that cracked section is and see if you can resolder it back properly.
Posted on May 28, 2011
electrotech1
  • 1126 Answers
SOURCE: Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Posted on Sep 14, 2011
Vizio 42 in smart tv won't turn off
The main board needs replacement. Yoiu can get the main board from www.tvrepairworld.com
Jan 01, 2013 | Vizio VW42LF 42 in. LCD HDTV
Jvc lcd picutre won't show
as you said jvc lcd tv won"t show. if lcd tv have good power supply & main board. that will be inverter board gone in. replace it will be solve you problem. good luck!
Sep 03, 2012 | JVC LT-42X579 42 in. LCD TV
Sony 42" won't turn on
TWO things to look at---inspect the lamp this model should use for brightness. Look to see what lights on front of set are on or BLINKING.
Jun 08, 2012 | Sony Grand Wega Kf-42we610 42-inch...
Proscan 42LA45H 42 in. LCD TV won't turn on, no red led when plugged
The power supply is the most likliest cause of the issue. You can get replacement power supply from www.tvcircuitboards.com
Mar 02, 2012 | Proscan 42LA45H 42 in. LCD TV
Olivia brand TV wont' keep channels remembered
This means that the memory is not working as it seems that the memory back up is not effective. it can be fault on the processor IC as the voltages , the data IN/OUT signals must be checked.
If voltage to back up is absent then there will be memory loss. If not the IC must be replaced, use proper soldering/desoldering irons with static protection when replacing.
Sep 21, 2011 | LG 37" LCD-TV 37LC25R 37 in. LCD TV
My remote for Olevia 32"
Hello
Chunchop remote has no setup codes with Olivia TV. Just buy one RCA RCR312W remote control. It has codes for Olivia, and most of the other TVs at present. You will get its maual with codes and proceedings about how to setup and synchronise it with your Olivia Tv.
The codes for Olivia with this remote control are:
11610, 11144, 11240, 11331
OK.
Sep 18, 2011 | Universal Remote Control Remote Control
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
My olivia exploded what can i do
Sound like it's time for a new TV, i dont know Olivia TV's but depending what has gone on it then it may be beyond economical repair, If it went bang then i would say its not good as that would be a high voltage component going and would more than likely take other compnents out. Are you Insured ?????
Dec 03, 2009 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
