Question about Kwikset Professional Door Lock installation Kit
I cannot remove the door lock to replace it.  It is a screwless type but i dont know the brand
  • Joe Neff May 11, 2010
    How old is the house? Is it an older door knob ( Like 30 years or older? ) What is the exact problem? Is it functional? Is it the Outside Entry Door or an Interior Door? With this and more description of the problem....I think I can FixYa.......Joe
  • 49 Answers
Generally, you remove the faceplate on the thin side of the door... there should be 2 screws there... then you'll see 2 holes on another faceplate underneath that one, which require an allen key of the right size... if your lucky you'll see a flathead bolt that can be loosened... then put your key only partially into the deadbolt and turn it counterclockwise and it will come out into your hand... then replace it or rekey it.
Posted on Sep 09, 2009
How to remove a parker screwless doorknob
There should be a spring clip between handle & door-panel-you can pop them with a small flatblade screwdriver or they sell door handle clip removers at all auto parts stores-Good Luck-JT
Nov 04, 2014 | Cars & Trucks
I have an exterior screwless doorknob that I need to remove. The faceplate on the inside knob that covers the screws is also covering the little pin that removes the knob. Is there another way to remove...
There is the 3rd version of the Kwikset exterior door set. The interior face plate is removed and on each side of the base plate has small slots with a lever on either side that need to be moved to the other end of the slot. The whole interior knob assembly with come off.
Dec 23, 2011 | Kwikset Locks & Locksmithing
I loaned my 2001 taurus to some one i think they may have made a door key i know they cant start it with this key but i dont want them in my car when they feel like it can you offer any advice
If you are really worried about it, you can always replace the door locks, and have a separate keys for the doors, and the ignition. A great place to find cheap door locks, would be a local junkyard. They are fairly easy to replace, you just have to remove the door panel, 2 bolts, and a c clip. If you dont feel comfortable replacing the locks, most shops will do it for fairly cheap.
Jun 16, 2011 | 2001 Ford Taurus
How to open screwless remote control (by Sony) (to clean dirty contacts)
there are locks in its four side. with out any wear and tear u cant able to open the remote. see the following video. else removing screw do the following
Dec 31, 2010 | Sony Televison & Video
How to open the case to upgrade rams
to open your cae make sure you unplug your power cable so that we can lesser the error..
first you need a scew driver...commonly screw driver is needed,
just remove the two scte in the back of your casing..then open it...inside you will surely see your old ram..remove it if you want or try to put the new one with the old one..
try your pc if it will turn on and go to your windows...
sometimes the it will not boot up,because the memories are not compatible with each other...
you'll need to replace the older one with the new one...
hope i've help you.. rate me,,
Feb 05, 2010 | Gateway 7200X PC Desktop
Motor wont run
Your door lock is bad. Don't trust the door lock light because this will fool you. Even tho door locks 1 of the circuits is not continuing. Replace the door lock. Very easy to do. Do this by peeling back the door boot at the lock side. Reach hands inside for access to wiring and remove door lock switch.
Jan 31, 2010 | Frigidaire GLTR1670A Front Load Washer
Need to install a door handle for 1998 hyundai
yes remove the panel, unhook the linkage one for the lock and one for the latch remove linkage from the handle not the latch, then remove blots holding handle then remove handle from outside the door, you will have to swap the lock to the new handle and then install new handle.
Nov 29, 2009 | Hyundai Motor 1998 Accent
Hi dear i have lngersoll deatbolt rim lock front of my door. i wanted to replace the only rim cylinder but i dont khow how to remove old rim cylinder. also can i use other company,s rim for my old...
The lock is removed after you undo the bolts on the inside The whole cenre should slip out. I doubt you can use another brand in the rim that will mate up with the equipment inside the house side of the door But you can completely replace it in the alreaqdy made hole
Aug 30, 2009 | Deadbolt PFK Touchpad Electronic Lockset
Removing front case fan from x blade
to access your fan you may need to remove the harddrive cage that is in the way. and the flashing led? sounds like your harddrive activity light. if that is the case it is normal for them the blink erratically
Jul 06, 2009 | A-Top XBlade Mid-Tower Case
How to replace inside glass on KitchenAid KERC608 Type 30P Range
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the lock position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
Jun 16, 2008 | KitchenAid Kitchen Ranges
Kwikset Professional Door Lock installation Kit Logo
684 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
