Question about Kenmore Refrigerators
Kenmore refrigerator 72102107
Water drains into refrigerator
4 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: kenmore colspot freezer drain line keeps freezing
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 17, 2009
EllaWatson25
  • 725 Answers
SOURCE: Kenmore 71182100 refrigerator will not cool after clearing drain
Hey Donna! It normally takes 24 hours for your system to go back into it's "normal" mode after it's been off. I would wait until tomorrow and see if it's cooling down properly before you worry. You may call me if you like after you wait the 24 hour period. Hope this helps you! Ella
Posted on Aug 17, 2009
Richie_asg1
  • 1036 Answers
SOURCE: kenmore refrig water runs from freezer drain
It sounds like they saved a bit of cash on this model by putting a T in the drain pipes of both - thereby saving 2 feet of pipe.
If the lower part of the drain pipe is blocked - it will flow into the lower section as you say.
You need to clear the lower drain pipe. Using vehicle wire (flexible PVC covered wire) will clear the blockage (turn off unit first). Then use an anti-fungal cleaner to remove the remains of the block.
You may even need to do this from the other end of the pipe that exits to a dish on top of the compressor.
Posted on Aug 30, 2009
Kenmore 10677181791 water dripping into refrigerator from freezer
probably an ice buildup around the drain tube not allowing proper flow thru to the drain. Try defrosting fridge for a while so the entire ice mass defrosts in between fridge and freezer
Feb 09, 2012 | Kenmore Refrigerators
Water inside Kenmore refrigerator
sounds like you have a frozen drain the easiest fix is to empty both the ref and the freezer, unplug the unit , keep both doors open for 24 hours to let drain thaw out. if problem comes back right away you have a blocked drain and the drain will need to be cleared
May 12, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Ice and water on the bottom shelf of my sears Kenmore regular refrigerator. things are cold but water pooling on the bottom shelf.it is a Kenmore freezer on top and refrigerator on the bottom
Drain stopped up. Defrosting occurs and condensation water must be evacuated, this is done through a dran hole. Clogged drain means water inside under crispers messy all that luv. Find the drain hole and give her a good old clean out. All will be good.
Jan 18, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 56549 Side by Side Refrigerator leaks wter
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 12, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Leaky bottom freezer on my kenmore elite refrigerator
defrost drain is clogged. defrost drain water is over flowing into bottom. take back panel off. remove ice to find drain hole. use very hot water and turkey baster to wash out till clear.
Jul 25, 2009 | Kenmore Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore # 63142 Fridge -- Water in Freezer
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
Apr 04, 2009 | Kenmore 63142 / 63144 Top Freezer...
Water under the bottom of the frezzer
I would thaw all ice out use hot water in the drain hole. also use a heat probe in the drain hole. Is the drain tube straight or does it have a trap in it.
Mar 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Need to clean out the defrost drain tube on our Kenmore refrige
remove the back freezer panel and the drain is below the coils in the drain trougth. use hot water to remove the ice to get to the drain inlet.
Dec 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
