Question about Coffee Makers & Espresso Machines
I took apart this machine for cleaning and I disconnect the wires now I am not sure were they go can you help me thank you
  • Coffee Maker... Master
  • 15,667 Answers
What do the two switches on the front of the machine do?
Posted on Dec 11, 2012
    Sergeant:
  • 462 Answers
Hard to know when no make or model is known bud
Posted on Dec 10, 2012
How do I put my foot controller back together, I took it apart because it will not turn off. My model # 66 - AA307535. Controller # 192257
more than likely, your variable resistor in the foot pedal is shot. cleaning is a low probability repair. replace the pedal assembly.
Oct 19, 2014 | Singer Sewing Machines
LG front loader washer model #wcvh6260fgg, we replaced the door boot seal, put it all together and now it won't run! It does light up and the laundry big dial select button works, my cycle and/favorites...
I had the same problem with my whirlpool and when I took it apart a wire had come out of the connector took it apart and put wire back in. problem solved. look for any loose wires also if u unplugged any connectors make sure u plug them back in where they were
Apr 04, 2014 | Washing Machines
Took my foot pedal apart, now it wont work at all, just makes a clicking sound when trying to put my foot down on it..
Hello
Unplug the machine plug and wall plug on the sewing machine.
Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
When you are done, reassemble the foot control and make sure it's working again.
Jul 12, 2011 | PfaFF Creative 7570
My air purifier dirty light keeps coming on, and the machine will not run, even though it has been repeatedly cleaned properly.
it obviously has a problem with the wiring. take it apart and make sure no exposed wires are crossing (wires without insulators) and make sure that none of the wires are disconnected
Jan 24, 2011 | Ionic Pro TURBO Air Purifier
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Took coffee pot apart in order to clean and cannot get it back to
There might be some ground in the corners where the tray sits.
Mar 12, 2010 | Saeco Vienna De Luxe Espresso Machine
CRAFTSMAN 42" kolher 15.5 hp. will start but have to leave the choke on or set it to idle.when running it surges. disconnect fuel line and crank it over and seams to be getting enough gas. but look at fuel...
Check the electric fuel solenoid make sure there is voltage to it when engine is running.This model may have 3 relays on the engine harness and one of them is tied into the fuel valve try switch relays.Also check connectors on ignition switch sometimes one terminal can get corroded and cause problems.Also check the plunger on it to be sure it is moving freely.Also the fuel filter is usually half full,there is almost always some air in it.
Aug 01, 2009 | Craftsman Garden
Coffee Makers & Espresso Machines Logo
18 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
