Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Clean light blinking, will not run at all - Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
  • Anonymous Jan 16, 2009
    I looked this problem up and all I could find was that the dishwasher has malfunctioned and to call a tech - i will post if i find a solution
  • pair02ss Mar 04, 2009
    It was the heating element. Thanks!!!
  • 188 Answers
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 03, 2009
Dishwasher blinking light
your owners manual fault guide will tell you what all blinking lights mean ie,,,how many blinks will tell you where the fault lies
Dec 29, 2014 | Samsung DMT300RFS Builtin Dishwasher
How do I clear a yellow light on my Scotsman ice maker?
Front panel has cleaning procedure if followed correctly it should of came off...if not quick way push clean let run 2 min sump full light has to be on push and hold clean button for 4secs blinking amber light should stop blinking let run for 2 mins.then push and hold until dash comes out unit shuts down and light is off... push green button continue to make ice
Dec 02, 2014 | Kitchen Appliances - Others
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
Clean light blinks, dishwasher won't run.
It is telling you that it needs to be cleaned. Remove and clean all filters.
If still a problem contact manufacturer. Most people think that a "cleaning" machine won't get dirty but they do, as bits of food etc get circulated and build up on the filters. These have to be cleaned every now and then.
Aug 10, 2014 | Maytag MDB8959AWS - MaytagR JetcleanR Plus...
Clean light blinks on whirlpool dishwasher won't run
When the light flashes 7 times it means there is/was a problem with the hot water, including a bad heater element. Flip the breaker for a minute and hopefully that will clear the error; otherwise, here's a website that will take you through resetting it.
Apr 04, 2013 | Dishwashers
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
ZEBRA P310 LIGHTS BLINKING
Seems like you just need to run a cleaning cycle on the printer. Both lights flashing means you have printed a high volume of cards without cleaning the printer. Please purchase cleaning kit 105909-169 to clean your printer.
-- The Pros at www.DiscountIDStore.com
Sep 14, 2009 | Zebracard P420I Thermal Card Printer
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
164 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
