Question about Canon GPR-7 DRUM FOR USE IN IR105 IR8500 MPN:6749A003AA SKU:1931576
How to face-up printing on canon ir8500 machine ?
How to face-up printing on canon ir 8500 machine ?
  • 62 Answers
SOURCE: canon ir 8500
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
Posted on Sep 11, 2007
SOURCE: E602 0001 - ir8500 Canon
Turn machine on while honding down the 1 and 9 keys.Machine will run a hardrive check program that takes 20-30 min.Power cyle main power in about an hour.If this dosn`t work system software and or new hardrive.$$$$$
Posted on Oct 16, 2007
SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Posted on Aug 05, 2008
  • 58 Answers
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Posted on Aug 07, 2009
  • 149 Answers
SOURCE: how to reset Canon IR 8500 Machine Admin Password?
you need to go into service mode...... additional functions...then the 2&8 at the same time .... then addit funct button again
then you will hit copier tab
functions tab
the clear tab
pwd clr
then hit the ok button
that will hopefully clear the admin password
Posted on Jun 09, 2010
CANON IR 7200 HDD SEUP
canon ir8500 error code000225-000codes
Jan 14, 2011 | Canon imageRUNNER 8500 Copier
Why better canon ir8500 than canon ir7200
Features - The Canon imageRUNNER 8500 benefits from a number of unique features including 85 ppm output, 4 trays online, 100 sheet document feeder, digital copying, built in duplex , network printing/scanning option, professional image quality and compact and reliable design. The Canon iR8500 can copy or print up to A3 paper size. This high volume copier provides an easy and efficient solution for work groups.
Sep 06, 2009 | Canon Office Equipment & Supplies
Canon ir7200 or canon ir8500 which one is best to buy
for my choice will be Ir8500, tough and reliable machine and high speed printing.
Sep 06, 2009 | Office Equipment & Supplies
How to replace HDD IR5000??
how to clear hard disk IR 5000 and where i can find hard disk software
Dec 20, 2008 | Canon imageRUNNER 8500 Copier
Ir 8500 E000246
A E240 is the reg. clutch or the DC controller or a loose wire, a E246 to me would be a problem with the DC controler or a loose wire going to the pcb. And the E225 or E226 has something to do with the counter pcb or the DC controler pcb. Also I would check the rom version of the copier. Also, was that the problem you went there for?? If not retrase your steps..
Oct 01, 2008 | Canon imageRUNNER 8500 Copier
E000019 Error Code for Canon IR8500.
Which model is it? IR-400 or IR-8500.... It has to do with the fixing dive.. I would say you need a service tech. You have to fix the problem in order to clear the code. Most times it could be the cleaning web is wraped around the UFR or the LFR has the LFR pick-offs dug in to the LFR or it could be the actural fuser diver gear on the fixing unit is gumed up or the ball bearings are seased up.... It's up to you????
Jul 17, 2008 | Canon imageRUNNER 400S Copier
IR8500 giving E000830-0000 Error code
Having trouble with my IR8500 getting Error code E000218-0000. Any Suggestions? Thanks
Nov 30, 2007 | Canon imageRUNNER 8500 Copier
Sep 17, 2007 | Canon imageRUNNER 8500 Copier
Canon GPR-7 DRUM FOR USE IN IR105 IR8500 MPN:6749A003AA SKU:1931576 Logo
41 people viewed this question
old marine
old marine
