Question about Panasonic SC-PT660 Theater System
Adding another external device to the sound system
I have the TV hooked up through the surround sound system (the Panasonic SC-PT660) using the AUX input connection but have audio cables (composite? component?) from my computer that I would also like to run thru the speakers......but don't seem to have enough inputs.....is there anywhere I could run it thru the TV then run that thru the speakers? Or could I use a splitter of some kind and attatch that to the AUX inputs to allow space for 2 devices?
  • janeblair2 Jan 16, 2009
    Went to Radio Shack.....got the switch box......works great!
    Now if I could just figure out how to hook the computer monitor.....well, actually the ability to project various fils (e.g. my pictures) onto the TV my life would be complete.
    Champion:
  • 240 Answers
Yes you are right you can pick up an arc aux swich box from radio shack.
will do your job just fine.
thanks
and pleas rate this, if is of help to you.
Posted on Jan 13, 2009
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Trying to connect Surround sound system with 3 Other Components!?
hi, you need to have 3 pair of audio-in ports for that. i think your sound system has 3 input ports. ie, 1.tv in ->u can connect this to audio out of your tv 2: vcr in ->u can connect this to audio out port of vcr 3: aux in -> this can be connected to your TV Receiver then you can use the soundsystem remote to switch between the source to listen one at a time. pls come back if u have any thing more sreejith
Aug 31, 2007 | Panasonic SC-HT75 System
I just bought the sc-pt660.Is there any way for me to hook my regular tv(not a flat screen or hdtv)or my time warner cable box to this to get sound from movies on tv.I dont see any audio in ports.thanks
You can use the PANASONIC AUX IN ports for your TV or CABLE BOX audio, unless you run the DIGITAL CABLE into the PANASONIC, this may be available on the CABLE BOX or your TV, my suggestion is if you use the Cable box to view TV then use the CABLE BOX AUDIO OUTPUTS, you would be better with the CABLE BOX digital output INTO YOUR panasonic, but if it is already being used take the AUDIO out analog connection from your cable box into your Panasonic AUX INPUTS, then set the Panasonic to AUX IN mode.
Feb 28, 2009 | Panasonic SC-PT660 Theater System
Panasonic SC PT660 Theater w Samsung Plasma -No sound w/Aux Input
My best advice is to do a factory reset on the system and then set it up again like you did when you first installed it. Unless your daughter physically damaged cables, the system should work OK. It's no use trying to work out what she disconnected as that will take even longer than a factory reset.
May 27, 2017 | Panasonic SC-PT660 Theater System
Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Jan 11, 2009 | Panasonic SC-HT680 System
Problems connecting phillips tv to panasonic sc-pt660 home theate
I just bought a sc-pt660, I have a philips tv too, the TV only available output is digital coax but the home theater only has digital optical input, you may buy a digital coax to optical converter like this one:
http://www.amazon.com/Cables-Go-Coaxial-Optical-Converter/dp/B0002J2MV4/ref=pd_cp_e_3?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B000I98ZQY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1BS8MKCZ1CWQR071S8RN
Alternativelly you can also use the headphone output that is near the side input in the TV and buy an RCA adapter like this one from radioshack: http://www.radioshack.com/product/index.jsp?productId=2103225
Jan 04, 2009 | Panasonic Home Theater System System
Sc-pt660 panasonic home theater system
If you press the Dolby PL button which is next to the functions button you should get your surround sound.
Nov 30, 2008 | Panasonic Home Theater System System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Panasonic SC-Pt 660
I fixed the main problem. It has inputs, not labeled as such. one set right next to all the outputs labeled only aux.after plugging in to the TV outputs, and putting the unit on AUX, this was fixed. The surround speakers were harder to work out, After downloading the manual, I was able to get sound out of them, however at a lower level than all the others. Even following the speaker level adjustments in the manual, cant get more volume out of them...I'll keep trying.
May 26, 2008 | Panasonic Home Theater System System
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Dec 12, 2007 | Audio Players & Recorders
Panasonic SC-PT660 Theater System Logo
305 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
