Question about Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2
Brad nailer will not fire staples/brads only air
When I fire the mailer only air shoots out of it , no brads or staples will come out.
  • 1388 Answers
SOURCE: air allways and continually leaks forcably from the top. Bostitch
This nailgun has several parts to the headvalve that must fit together properly to seal. Go to WWW.toolpartsdirect.com for a diagram of this tool. The part called the diaphragm is source of problem. It has thin vinyl walls that will fold over when you assemble. The piston will not cause the gun to leak, just make sure that piston fits snug into the cylinder. Loose oring on piston will only cause low power or the poston may not retract all the way back up. Some piston/drivers had a plastic ring instead of an oring. The plastic ring had a secondary oring under, however not necessary. You can use rubber or plastic, just make sure that the piston is not too tight or too loose. The piston oring is the only oring in the gun that can be cut to fit. It is like a piston in a car engine. The piston rings have a gap.
Posted on Nov 25, 2008
muttandjeff
  • 359 Answers
SOURCE: I have a ridgid brad
insert a open fitting adapter into the connection end and make sure you are getting a good air flow with open ended connector hold away from face and eyes while doing test and be sure the fitting is well seated into coupler before releasing . let me know result
Posted on Dec 29, 2008
  • 5 Answers
SOURCE: Nails won't shoot
I had same problem with my brad nailer. The piston inside the main housing seemed to be gummed up and sticking. There was a vent on the top of the cylinder for the exhaust. When I would blow through this vent it would push the piston down and the nailer would start working. This is definitely not a permanent fix but might get you through the current job before you open the cylinder and see why it is sticking.
Posted on Mar 31, 2009
rowdy45176
  • 2176 Answers
SOURCE: My brad nailer will not shoot any nails. When I
it sounds like the piston/driver might be stuck or the firing valve is malfunctioning. there are 4 screws to remove the top cap and you can see if the driver is damaged. Also before removing check to make sure there is not a nail jammed in the nose assembly. This tool is good for breaking the pin on the piston.
Posted on Oct 16, 2009
rowdy45176
  • 2176 Answers
SOURCE: brand new brad nailer shoots 2 nails and then it
first make sure that you are using the right guage nails and if so I would return it to the place of purchase for replacement., the blowing of air could indicate a jammed nail in the track, look for that first and make sure the driver is retracting fully.
Posted on Dec 19, 2009
Mastercraft brad nailer model 57-7900-2 5/8" - 2"
No experience of Mastercraft brad nailers but if fires with out depressing nose tool is dangerous and should be returned to manufacturer. Dewalt make battery powered brad guns and recently produced a battery framing nailer. I would not say that other nail guns are exactly cheap if they are beware they may not be up to the pressures excerted on the whilst firing.
Jan 24, 2014 | Air Tools & Compressors
Brad nails crooked in bostitch
Have you inserted the correct Brad Nails? What is the code of brads you have inserted? Is the tool jammed?
Solent Products Air Nailing and Stapling Supplies
Mar 21, 2013 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
What kind ryobi p300 staples & brad nails
Nice little nailer Fred. Here are the details (sold at Lowes or other lumber centers).
Staple Size 3/8 in. Crown Width, 1/4, 5/16, 3/8, 1/2, 17/32, 9/16 in. length
Brad Size 18 gauge, 3/4, 1, 1-1/4 in. length
Magazine capacity 100 staple/brad Good luck with your projects
Oct 14, 2011 | Ryobi P300 One+ Stapler Brad Nailer
What kind staples p300 stapler brad nailer
These are sold at Lowes and other lumber centers.
We don't know how to put in new staples. We r fixing a chair
If your brad nailer is a BN200; I don't believe it will accommodate staples.
Feb 14, 2011 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
My brad nailer shoots staples without any problem but it jams on the second brad after being freed up from the previous jam. How to I rectify this problem. It is a fairly new stapler/nailer and has done...
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
Mar 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
The gun will fire staples, nails do not set.
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2 Logo
50 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
