Question about Tomtom ONE GPS Receiver
TomTom One does not power up - burnt component D5 or D9?
I have a TomTom One New Edition that no longer comes up. The green LED is not on either. This happened a couple weeks ago in the car and there was also a burnt component smell that was present. I have opened up the unit and there is one very small charred component in the left bottom corner that is labeled either D5 or D9. Would anyone know what this component is and where I can buy one? My guess its probably a diode or rectifier of some sort.
thanks
  • 1 more comment
  • junmorales Jan 14, 2009
    i've got the same problem, its actually D5 and i'm looking towards a resolution to it as well
  • gls_1959 Jan 19, 2009
    Using an USB microscope, I've been able to identify the markings on D5. There is a cathode mark on it as well as what looks to be a 0.5 or a omega symbol .5. My guess is that its a plastic 2 lead diode of some sort but there is no way to identify the value or mfg. The research continues....
  • Marlon Guishard
    Marlon Guishard Mar 15, 2009
    You will need the schematics to see the value of the D5 & D9 items. They could be capacitors as well. Mine just will not turn on. I have push the reset several times, held down the power button for several minutes,
    and still nothing. I get the green light when it is connected to my computer usb or to the car adaptor.
TomTom One uses a Linear Technologies chip LTC3455 as a USB/charger power controller. See http://cds.linear.com/docs/Datasheet/3455fc.pdf. This chip is susceptible to high transient voltages that result from resonances created by parasitic inductances and capacitances of the USB/in-car charger cable . Good designs using this chip suggest that a 1 ohm resistance be put in the path of the cable to reduce the Q of the resonance and hence transient voltages. A 6V Zener diode D5 also serves to protect the chip from these transients.
If the Zener diode is blown it is most likely the the LTC3455 chip is gone as well. You can replace the chip which costs £5.00 (located in the shielded portion of the PCB). The recommended Zener Diodes for this chip are either the EDZ5.6B or EDZ6.2B manufactured by ROHM (http://www.rohm.com/products/databook/di/pdf/edz5.6b.pdf or http://www.rohm.com/products/databook/di/pdf/edz6.2b.pdf). These can be used to replace D5. The STMicroeletronics SM2T6V8A can also be used to replace D5 (http://www.st.com/stonline/products/literature/ds/8694/sm2t.pdf). All the Zeners cost a modest £0.22. I hope this is helpful.
Emmanuel Zyambo
Posted on Oct 10, 2009
Hello mayby i help You. I am from poland and my english may be not wery good.
D5 is fast diode approximately 3A but when is damage also you need to replace 3455 power chip like this:
http://obrazki.elektroda.net/83_1217150255.jpg
after that tomtom will by repaired if You have more question send it to:
horaczy@gmail.com
Posted on Apr 23, 2009
Have a burned electronic component--no schematic and need to know what component number PL1 is named or consists of.
I have a tomtom one 3rd edition gps and i put a charger that is too powerful on it and think i burned it, but when i put it on charge the little green led light glows and it wont turn on. could i have burned the battery
Nov 12, 2010 | Gateway M-6755 Notebook
My tomtom charges the green light comes on I press the on button but nothing happens
I have managed to fix my TomTom one.
The problem was two fold. First the diode D8 was blown and also the power supply chip was blown.
It is a tricky job, using surface mounted components so should not be attempted by a novice but I managed it.
I have a full set of photos etc if anyone cares to try it. I figured - NOTHING to loose!! so what the heck and just went for it. Taking it apart was fun! The surface mounted IC was easy to obtain and the total cost was about £10 plus 4 hours panic labour. If anyone wants the info just let me know and I will send the photos - but no promises - it worked for me.
I figured out this ongoing problem. I purchased my TomTom One second edition 1/20/07 for $395. I was 30 days past my warranty and had the problem of unit not turning on. Green light came on when charged.
I opened my unit up and found the sw2 micro switch broken. If you press too hard on the on/off button, this will eventually happen.
I couldn't find a replacement switch so I wired my own switch and it works now.
Oct 26, 2010 | Tomtom ONE XL GPS
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
Tomtom not turning on
It sounds like the dreaded green light of death. The TomTom car chargers for this model and older had a inherit problem with sending more than the requaired amount of power to the TomTom 3rd edition and older models. When the extra power is supplied a diode in the TomTom burns out, but the green power light will come on.
Nov 29, 2009 | Tomtom ONE 3rd Edition GPS
How do I burn/copy a DVD
you have to rip the dvd using software like DVDRipper. Then you can burn the resulting file to a 4.5 GB DVD. Usually the movie will be around 7.5 GB and the ripper reduces the size to fit that.
Sep 18, 2009 | Computers & Internet
Tomtom wont charge
the plug end(cigarette lighter end) may have an internal fuse. the very tip screw off and inside is a small glass tube style fuse. check that.
Aug 08, 2009 | Tomtom ONE 3rd Edition GPS
TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
Green Light / Dead Tomtom - Please help with component id
that diode is a reverse polarity protection diode. An 1N414 will do ( available for very very little from almost ALL electronic component suppliers.) If there is NOTHING ELSE WRONG then the tomtom will still work without this diode. Its not needed in normal operation anyway. All it does is cause the fuse to blow in the cigarette lighter plug if the polarity is accidently reversed. Therefore , with a correct supply , it does nothing !
Aug 18, 2008 | Tomtom GO 300 GPS Receiver
Require value of D5
Emmanuel Zyambo
Jun 15, 2008 | Tomtom One XL GPS Receiver
Tomtom ONE GPS Receiver Logo
4,950 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
