Question about Garmin StreetPilot 2720 GPS Receiver
Searching for satellite but never finds - what is wrong?
My Garmin GPS says it is searching for satellite but never finds. Can it be fixed?
    Problem Solver:
  • 7 Answers
I had one like that last year, I found if I lied to it when it asked what state I was in, then it would find the satellites and work fine ... until the next time you turned it on. That one was fixed by installing new v7.2 firmware using Garmin WebUpdater through the USB port.
I've got one right now that won't find the satellites and the firmware trick didn't work. That's all I've got so far. Tom.
Posted on Jan 24, 2009
My Garmin Edge 705 keeps searching for satellite without succes
If you are handy ,open it, Disconnect the battery for a few minutes.
Assemble and it will fix the probem. It worked for me.Will probably
work for all navigators
Aug 28, 2013 | Garmin Edge 705 Handheld GPS Receiver
Can't find any satellites
If you don't use it very often it can take time to find its location. Have you tried using the 'set initial location' option? Once it knows roughly where it is and what time it is it can then work out which satellites it should be looking for instead of searching for any/all of them. The manual does say that it will take time if it has no initial clue as to where on the planet it is, and if you're on the move while it's trying to work that out then it may take even longer. Obviously, if it has a poor view of the sky, or if most of the satellites are behind you and you have a tin roofed aircraft then that will probably not help either.
How do you know the antenna is OK?
Do you have the remote antenna to try?
Mar 18, 2009 | Garmin GPSMAP 295 GPS Receiver
Garmin GPS 75
Install batteries in the unit, turn it on and set it outside for several hours with a clear view torward the sky. It probably had not been used for and extended period of time and needs to re-sync.
Frank
Oct 02, 2008 | Garmin GPS
First, be sure you are outside, in the open when making this diagnosis. Some cars have metallic defrosting layers, which blocks the GPS signal. Also, first fix when new may take several minutes (5-10 minutes).
If, when outside in clear view, you still have problems, try this...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jun 09, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Jan 02, 2008 | Garmin 60 GPS Receiver
My Garmin has stopped finding destinations - just says "Searching for Satellite)+
I had the same problem with my Nuvi 310. Found a solution in here that works. Here's a copy of the advice.....note you will need to get in the car and set it for a destination and go. 5-10 mins later the Garmin Nuvi will lose the satellites, but don't adjust it it, leave it on and keep going. Eventually after about an hour it will right itself, pick up the satellites and evrything will be back to normal.
Here's the advice:
happy2surf
Rank: Apprentice
Rating: 81%, 49 votes
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching!
The unit appeared to have "stuck" in this acquiring mode. The following worked for me:
1) open the GPS antenna
2) press the bottom left screen while holding the power button to turn the unit on
3) enter maintenace mode
4) select diagnostics
5) clear error report, do NOT clear any user data
6) restart unit the usual way
My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Dec 05, 2007 | Garmin nuvi 350 GPS Receiver
Garmin IQ 3600
It sounds like the micro switch for the antenna has busted and it now thinks the antenna is up always. It will have to be professionally repaired.
Oct 01, 2007 | Garmin iQue 3600 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
361 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
