Question about Dishwashers
Fisher and Paykel DD24DCX6 Handle replacement
Does anyone know where I may find disassembly/assembly instructions for the Fisher and Paykel DD24DCX6 dish drawer? I received a new handle, however it did not come with any instructions, and my on-line search thus far has come up with only a parts list (bust). Thanks
2 Suggested Answers
  • 842 Answers
SOURCE: Fisher & Paykel DD24DT Dish Drawer Dishwasher.
Michael,
Part number I came up with was a 522898, this handle comes in black, I assume this would be correct for the particle model number you gave here. I hope this helps, Fisher and Paykel number 888-936-7872 and they can send you the parts you seek directly. You will need to have the complete model nmber to order from them. Good luck.
Posted on Oct 29, 2011
How do i replace a fisher & paykel dw691ed ss handle
Refer this parts diagram.
http://spares.bigwarehouse.com.au/images/files/18196_71ac2010b1b67e91c23c267b28e0cae7.pdf
You have to remove the screws holding the front panel and access the door handle to replace it. Make sure the mains power chord is taken out from the plug.
Dec 14, 2013 | Fisher and Paykel Dishwashers
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
I have a Fisher Paykel double drawer dishwasher. The wash load selector buttons won't work. I used to be able to press the arrow button on the left and it would cycle through all the choices. Now,...
Unfortunately the buttons are an integral part of the Control Board. If it turns on just wont change cycle it could be that the controller is not sitting in place properly, otherwise you would have to get another controller.
A couple of things to try:
Make sure it is dry, some can be really sensitive.
The opposite, Put a bit of water on the pad or lick your finger.
Touch something metal like a tap with your other hand while you try.
If you want instructions on checking the controller is in place let me know.
Aug 12, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
How do I replace handle/plastic cover on Fisher and Paykel soft touch 913t dishwasher?
Not sure if you have tried to refer to the parts manual itself which shows how the parts are assembled together. In particular page 8 which shows the handle assembly part 18. I am assuming this is what you are replacing. Or is it just part 21 which is the plastic latch recess cover.
Mar 21, 2013 | Fisher and Paykel Dishwashers
FISHER & PAYKEL dd24 , i CHANGED THE ROTOR MOTOR BECAUSE OF THE F2 CODE AND IT WAS BURNT, BUT THE CODE STILL POPS UP AT START UP ?
Need to clean the pump sump and the drain sump to make sure there is no debris left. Most likely a bone chip or seed inside the channel connecting the two sumps. Use a thin rigid wire to clean.
Feb 27, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
Fisher & Paykel DD24DT Dish Drawer Dishwasher. Handle is broken. Need to know if I can purchase a handle assembly, if so any idea on a Part number?
Michael,
Oct 28, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do i change the handle on the double drawer fisher paykel dishwasher
You will have to get the front cover out by unfastening the large plastic tags on each side.
Be careful not to drop the front cover as the handle and display will fall down. Taken it out slowly and carefully. The handle will come off as soon as the front cover is taken off.
I am assuming you have already purhcased the new handle assembly.
Put in back in reverse order after you replace the handle.
Please rate this solution if you are satisfied otherwise post a comment.
May 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Open Questions:
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
