Question about Dryers
Hot to test a thermal limit switch for my dryer
I want to test my limit switch with my ohm meter to see if it's any good
    President:
  • 1,922 Answers
If its the high limit thermostat it will test just like a switch closed it will read very low ohms,open it will read infinity "OL" on some meters
Posted on Dec 11, 2012
  • 1073 Answers
SOURCE: Estate dryer won't come on..
check the white thermal fuse on the blower housing
Posted on Apr 26, 2008
SOURCE: Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Posted on Jan 04, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Posted on Feb 05, 2009
  • 949 Answers
SOURCE: Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Posted on Apr 23, 2010
Testimonial: "Great advice, thank you for your help."
  • 113 Answers
SOURCE: Maytag Neptune Dryer Model #MDE4000AYW
It is dangerous to do but you have to turn dryer on while it is apart and wait for limit to open up, then test. !st make sure all connections are ok. The clips and the nuts all need to be tight. If any look dark or burnt that may be your weak link. If you are sure that everything is else is working ok, a set of high limit switches is not very expensive. The voltage is 220 so if your careful you can test at each junction, but be careful..
Posted on Sep 18, 2010
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    Have power everywhere but won't turn on
    see this causes and fix it. God bless you
    1. No power to the dryer
    Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
    2. Door switch / Door switch actuator lever
    The dryer would not start with a broken door switch. Replace the door switch if found defective.
    Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
    Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
    Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
    Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
    Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
    Oct 02, 2012 | Dryers
    I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
    Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
    Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
    Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
    Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
    Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
    Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
    Sep 28, 2012 | Bosch Nexxt 800 Dryer
    Frigidaire affinity Dryer wont turn on
    see this causes and fix it.God bless you
    Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
    I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
    Sep 28, 2012 | Dryers
    Heating element starts to work and then shuts down after about 5 seconds
    You may have a thermal limit switch going bad. These devices are in line with the element to keep the dryer from getting too hot. If one of them is defective, it will shut the voltage off to the element. If you are able to, check the thermal limits and your element, using a volt meter in the ohms setting. If the meter reads open after you hold the leads across the switch terminals, replace the device.
    Feb 11, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
    My dryer keeps blowing the thermal limiter fuse or switch,what ever it is called.why?
    Hi candwloc..
    If the thermal fuse /thermostat overheats the dryer will not operate.
    It's located on the blower housing and it cannot be reset.
    A vent clogged with lint can cause the dryer to overheat and keep blowing the thermal fuse/thermostat.
    You can test it with an Ohm meter or continuity checker, if no continuity, replace it.because it is faulty.
    Please take time to rate me
    Jul 24, 2011 | Frigidaire FEQ332E Electric Dryer
    Dryer not heating - I replaced the heating element and it still isn't drying.
    • Rank: Guru
    • Rating: 92%, 36 Votes
    Yes there is a thermal fuse and a hi limit switch. The hi limit switch is attached to the heating element casing. You said the heating element checks out If you checked it with an ohm meter and it checked out good. If you checked it visually double check it. The hi limit can be checked with an ohm meter it should show continuity. If you dont have a ohm meter you can jump the wires by connecting them using a paper clip or copper wire. Make sure to tape them with electric tape. The thermal fuse is connected with the Heating element and hi limit by one wire and is located at the bottom back of the dryer and slightly to the right as you face the back of the dryer. It is a small two wire fuse and once it trips you have to replace it you can check it and test it just like the hi limit switch. Be careful and always unplug the dryer before starting any repairs. I hope this help. If you need me to clarify anything just let me know. good luck
    Aug 25, 2010 | Whirlpool Dryers
    A Kennmore electric dryer, model 697267. Heating element checks out ok. Soninlaw said breakers are ok. Dryer drum turns but no heat? I'm 640 miles away, is there a thermal fuse in the circuit.
    Aug 25, 2010 | Dryers
    The dryer is not heating
    Hello there here is a list of things to check
    Testing with an ohm meter checking on a dryer....
    These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
    Meter testing and usage tips.
    1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
    2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
    3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
    4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
    5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
    6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
    7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
    But darn it, I don't have a Ohm Meter....
    To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
    To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
    To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
    How to take apart information for GE style dryers
    How to take apart information for Inglis - Whirlpool - Kenmore dryers
    How to take apart information for Maytag dryers
    How to take apart information for Frigidaire and White Westinghouse
    Jan 09, 2010 | Dryers
    Dryers Logo
    59 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
