How to hook the speakers with the sony STR-DE405
    Top Expert:
  • Audio Player... Master
  • 35,584 Answers
I have a Sony STR-DE405. The front speakers are connected to the FRONT SPEAKERS A terminals L and R. If you are installing surround speakers, they are connected to the SURROUND SPEAKERS terminals LR, RR, and center (front). This model does not have an active wooker connection. The FRONT SPEAKERS B terminals are for connection of a second set of front speakers
Posted on Dec 09, 2012
marsrover
  • 682 Answers
SOURCE: STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Posted on Aug 02, 2008
bunnydawg
  • 5158 Answers
SOURCE: sony str-da3000es
This appears to be an error message that is given due to copy protection on blue discs....
Robert
Posted on Dec 17, 2008
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
remington870
  • 48 Answers
SOURCE: hook up wireless speakers
I'm assuming the wireless speakers you have utilize an RCA jack to connect to the receiver.
Solution:
The good news is yes, you can use them on your receiver. The bad news is that the only output on your receiver is "VIDEO OUT" so whatever you want to watch or hear on the wireless speakers must be connected to the "VIDEO INPUT".
If the wireless speaker module uses speaker wire to connect to a receiver you will simply tap into the surround thumb clip speaker jacks.
I will add that wireless speakers tend to be disappointing when used in home theater.
Posted on Mar 31, 2009
Nomodo4u
  • 863 Answers
SOURCE: I have hooked by two bose 161 speakers using 14
You gots ta isolate the problem.  Disconnect the speakers and hook them up to a stereo you know that works.  If you don't hear sound coming out of the speakers, then you know the speakers are fu.k.d up, so you need to look on the speakers to see if there is a fuse that is blown that needs to be replaced.  If you got sound coming through, then disconnect them and hook them back to the original stereo making sure you got a good connection and all the wires are in good and tight.  Then turn your stereo on and go through the various channels like Tuner, Tape Deck, Aux, and DVD to see if you get any sound.  Also turn the volume knob up. If you don't get any sound after all this, you know there is something wrong with the stereo your using.
Posted on Oct 29, 2009
Testimonial: "Great advice. Will check and update ASAP. tX."
Will not turn on, is therd a fuse I can replace?
There are fuses for the radio in the fuse box and also behind the radio itself.....check fuse box first!
Jun 06, 2015 | Sony STR-DE405
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
Can i use front output A and B to bi amp my wharfedale 9.5s
Technically, yes, but the same audio would be traveling across the two pairs of wires that would be arriving via a single pair to the jumpered speakers. NO electrical difference.
Read up on bi-amping and by-wiring (BUY-wiring) before pursuing that path. The underlying presumption of an improvement from either is that there are deficiencies in your system to begin with. It's all snake oil designed to sell cables and amps.
Aug 22, 2011 | Sony STR-DE405
I have a sony str-de 405 recevier . how do i connect a subwoofer to it .....
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE405-Receivers-manual/id/387bh944/t/2/
and refer to the manual that should have come with your unnamed subwoofer.
Mar 21, 2011 | Sony STR-DE425 Receiver
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
Sony str de405 receiver...was working fine, now no sound
I have a problem with vintage reciever Sony STR-11L. Power transistors were replaced and I dont know what were original ones. Sound is no good and radiator is hot-I think problem is in replacement. Can anybody help me with?
May 14, 2009 | Sony STR-DE405
Tremendous Rumble when using my new turntable
its more like your turntable needs to be isolated from surrounding interference? try putting foam or dense rubber under the feet and make sure its not anywhere near a speaker as this wil cause immense rumble problems? it may be your carridge on this new deck is way more sensitive than your previos set up and therefore needs isolation for the best results?
Apr 21, 2009 | Sony PS-LX250H Turntable
Jul 06, 2008 | Sony STR-DG800 Receiver
342 people viewed this question
 Grubhead
Grubhead
