Question about Saws
Parts manual for Husky Tile Saw Model THD950LN
The motor break on my tile saw seems to have piled up. Stops with a clunk and lossens off the blade. Is there a parts manual available and where can I get parts in Canada.
  • 2712 Answers
SOURCE: how to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Posted on Aug 27, 2008
thabrain
  • 76 Answers
SOURCE: Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Posted on Nov 05, 2008
  • 29 Answers
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Posted on Mar 26, 2009
  • 29 Answers
SOURCE: Tile Saw Troubleshooting
if your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
SOURCE: need to purchase replacement part for a wts200l rigid tile saw
TILE SAW WTS2000L ;THE UNIVERSAL GUIDE CATALOG NUMBER #:6006001.I NEED TO BUY ONE
Posted on Apr 12, 2009
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Cutting porcelain tile with wet saw and it breaks at the end of the cut?
Porcelain tile has to be cut painstakingly slow, especially the last inch or two to prevent the splitting problem you are having. When you are cutting tile, the sawblade rides up just a little as the tile is being fed into it. You'll notice it if you stop pushing the tile through and watch the head drop down just a bit. When you are getting to the last part of the cut, reduce the pressure you are using to push the tile into the blade so the blade can wear away the tile with little pressure and vibration as possible.
Dec 30, 2012 | Mk Diamond MK 370 TILE SAW
Huskey tile saw thd950l motor how much would it cost motor #c5d41884?
Take a look on amazon for sure. Amazon com Husky tile saw. If cant find just a motor, for sure there is someone to answer that question (someone who sells husky saws...). I hope this was helpful. cheers
Apr 12, 2011 | Husky Wet Tile/Stone Saw with with Laser...
I need a owners/parts manual for a husky TDH950L tile saw
try here ->http://www.huskysupport.com/files/thd950usermanual.pdf
Apr 04, 2011 | Husky Wet Tile/Stone Saw with with Laser...
Need parts for husky tile saw THD750l need bolt fence
Hi, Take a look at amazon for replacement parts: Amazon com Husky tile saw. Hope this was helpful. cheers
Sep 30, 2010 | Husky Wet Tile/Stone Saw with with Laser...
MY SWITCH WENT OUT ON MY TILE SAW WHERE CAN i GET
You can get the part from husky website at:
http://www.huskysupport.com/products/product.aspx?ID=4
From there scroll down till you see part number
6102018
switch Knob for $5.38
Hope this is what you are looking for
Nov 30, 2009 | Wet International Husky 7" Wet Tile Saw...
I have a husky thd950L wet tile saw and the on/off switch broke. Where can I find a replacement part?
I need to replace the ball bearings in my Husky THD950L tile saw. Please tell me where I can find them.
Oct 08, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Husky wet tile saw repair service
I need to order a part for my Husky wet tile saw. can someone give me an email address. web serches are a bust.
Aug 24, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
I just purchased a Hitachi C12LSH. The blade hits the guard in the cutting trough. How do you move the saw blade to center it?
you should be able to adjust blade up a little bit, you only want blade to cut through tile bout 1/4 inch ,should be big knob you lossen to lift up motor and blade good luck
Aug 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
Saws Logo
644 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
