Question about Dewalt Tools & Hardware - Others
My 18 gauge air nailer is shooting some of the nails in a u-turn and damaging my wood.
I'm using an 18 gauge brad nailer to join mitred corners on custom frames. My frames are clamped in a mitre vise and I shoot into the sides. Some of the brads are shooting up and in a u turn- breaking through the top of the frame. What might be causing this to happen? I have cleaned and lubricated the gun and checked the psi several times. Sometimes it works fine, but at times, it will fire incorrectly, once or twice in a row, but then fire correctly.
    Champion:
  • 304 Answers
Contact Alpha Pneumatics. 01707 282700 they might be able to help.
Posted on Dec 17, 2012
rowdy45176
  • 2176 Answers
SOURCE: Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: Nails won't shoot
I had same problem with my brad nailer. The piston inside the main housing seemed to be gummed up and sticking. There was a vent on the top of the cylinder for the exhaust. When I would blow through this vent it would push the piston down and the nailer would start working. This is definitely not a permanent fix but might get you through the current job before you open the cylinder and see why it is sticking.
Posted on Mar 31, 2009
comax
  • 154 Answers
SOURCE: Mastercraft Brad nailer piston always fires
The dial on the top of the gun is most likely the depth adjustment for the nails, this should solve the driver damaging the work piece. Make sure the nails are the correct guage for the nailer you have.
Posted on Apr 14, 2009
efs_perpends
  • 1996 Answers
SOURCE: Framing nailer intermittently doesn't shoot the nail.
Make sure to blow out the magazine where the nails load, make sure the spring tension on the nail clip is working properly, make sure you're not holding the clip somehow with your off hand so the clip can't feed correctly.
Posted on Apr 20, 2009
  • 131 Answers
SOURCE: Porter Cable 2 inch brad nailer piston does not return
Sounds like the cylinder check seal. That`s the o`ring on the outside of the cylinder sleeve. With little holes in the groove. You have to remove cylinder sleeve to get to it.
Thanks,
Jeff
Posted on Jun 24, 2009
Why does bn200a nailer shoot double nails
Check your compressor Pressure - it need to according to nail-gun specifications.
Usually it is mechanical pressure switch failure. Replace all with digital Controller.
Jul 14, 2014 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Brad nails crooked in bostitch
Have you inserted the correct Brad Nails? What is the code of brads you have inserted? Is the tool jammed?
Solent Products Air Nailing and Stapling Supplies
Mar 21, 2013 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I am trying to obtain 18 gauge brad nails for a clarke air nail gun ,can i use any type of straight 18 gauge brad or do clarke make brads for their own tools
you should not have any problem with using any other brand of nail .18 gauge brad nail are pretty much the same in all brands.
Mar 30, 2011 | Air Tools & Compressors
I have a 18 gauge 2" brad gun when you plug the
Increase air pressure.... you're way too low......
Dec 02, 2010 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
My Bostitch SB 2in1 nailer will only on occation nail all the way into the wood. For the most part the nail will bend over before it goes in, which damages the wood. I spend more time tying to pull out...
I ran into this problem many times. Don`t use the Bostitch brand nails. Use the generic or other name brand. You`ll notice the generic one`s heads are just a little bigger and the driver blade won`t run down the side of the nail!
Thanks,
Jeff
Jan 05, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Brand new brad nailer shoots 2 nails and then it blows air
first make sure that you are using the right guage nails and if so I would return it to the place of purchase for replacement., the blowing of air could indicate a jammed nail in the track, look for that first and make sure the driver is retracting fully.
Dec 18, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
My black and decker 18v brad nailer will not shoot brad
look to see that you are shooting the right sized nails in it. 16 and 18 gauge nails dont interchange and the can get hung up under the plunger if the try to shoot at all
Dec 15, 2009 | Tools & Hardware - Others
Shooting 2 nails at a time and then jams
make sure you are using 18 gauge brads in the gun. also if the brads have gotten wet or are old, the paper or wax coating on the becomes weak and it will release more than one nail at a time. try different brads in it.
Dec 15, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Tools & Hardware - Others Logo
87 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
