Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Reprogramming maytag mf12568aeb fridge after replacing hv board 12920710
SOURCE: how do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Posted on Oct 30, 2007
  • 220 Answers
SOURCE: I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
Posted on Sep 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: I Have Maytag mfi2568aes I replaced both the HV
On most the motherboard will reset itself once unplugged. I believe you need to test the low voltage power supply transformer. This by far will not be a one answer solution so if you could follow through the service manual and technical notes with me I will be glad to assist you. Any time a board is disconnected on your model the motherboard should reset back to factory settings once disconnected from a power supply. Hope you have not discarded the old boards and you can put them back in and see if something is different. Let me know later what you decide to do. For now I will leave these=> Service Manual and=> Technical Information I will return later to see if you respond. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on May 14, 2010
Testimonial: "Thank you. Your Tech information was the KEY to the fix."
sodeep
  • 3267 Answers
SOURCE: Replaced HV board on Maytag MFI2568AES fridge.
increase the thermostat settings to a more cooler temperature
Posted on Dec 28, 2010
SOURCE: HV board problem. replaced board, but can not reprogram to enter new code. what do I do?
I recently had the identical problem after replacing the high voltage control board myself. Although display looked normal, no response to programming attempts. All I could think of was that the low voltage board under the display ppanel was also bad and was about to go out and buy it ($240 locally) when I ddecided to check its connections first. Took off the display panel, unplugged the 4 connectors, plugged them all back in. When I powered up the fridge, it responded to the programming directions and has been working normally except the ice-maker made one batch of ice and then just stopped. Now I have to try figuring that one out.
Posted on Aug 11, 2012
MF12568AEB control panel on door went blank. Fridge is running but no lights, no water, no ice, no controls
First test the plug connection under the hinge cover of the door that has the controls in it. This is to insure that the male and female plug connections are tight. Next we will need to check the dispenser control board and keyboard electrical connections are tight. Let me know the results.
APPLIANCE 911
Nov 17, 2015 | Maytag Refrigerators
The ICE2O has gone crazy
Billy, your HV control board has failed. (I know this because I serviced one just last week for the same symptoms and promptly diagnosed and repaired it.) The board can be accessed from the back of the fridge. Roll it out from the wall and look about 2 feet up from the floor on the left hand side. You'll see the cover held in place by 4 1/4" screws. Remove 3 and loosen the last one, rotate the panel out of your way. The board is a snap to remove and replace. The part number you will need is #12920710 and is available at your local appliance parts retailer. It lists for ~$150.00. The kit DOES come with instructions to program it once the repair is complete. Read these completely BEFORE doing the repair so you'll know what to do when you've got it back online.
Aug 13, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
How to turn off MAYTAG MF12568AEB
Pull fridge out from wall & swithch of @ power point.
Nov 21, 2013 | Maytag MFI2568AE Side by Side French Door...
Aug 11, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Dispenser Board
You must have a Kenmore. You can go to searsparts.com to get sears part number. HV board is not the same as dispenser board.
Jul 23, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
I found the problem and the answer to my problem BUT the part is backordered and I am wondering
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Jun 19, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
FRONT DISPLAY SHOWS (PE0-000)
Usually the owners manual would show the error codes so check there first. As for the compressor running, it "should" be cooling if the compressor is running. But lets go back a little, why was the HV board replaced?
Feb 05, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
108 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
