Question about Dryers
Frigidare model faqg7072lw saying door is open when its not
Its saying that the door is open when its not and wont dry
Frigidaire washer door catch is stuck, washer won't run
After looking at the schematic of this machine it seems that the door AND the control board have to work perfectly together in order for the safety mechanisms to operate correctly. You may have a bad control board or a loose wire. The best thing to do is look closely at a schematic and make sure that everything looks right. here is a blueprint: http://www.pcappliancerepair.com/model/index.php?id=FWT449GFS1
Jan 03, 2014 | Frigidaire Affinity ATF7000E Front Load...
How can i disconnect the timer on my electric range. Its not the loud buzzard its a noise behind the timers that sound similar to a loud coffee pot perking. I no longer have a manual. but its a Frigidare...
No the problem is not solved. Sorry to say there are alot of people out there who will help without paying someone for a small email. Electrician lives next door and he is coming over today to stop the timer. Guess what, wont cost me anything.
Thanks
Dec 20, 2009 | GE JBP66 Electric Kitchen Range
Model LDE303 worked fine once we got the right
seems like the door safety switch is stuck. open door and look for it, a little dowel, see if it is clicking on and off. to test, open door, let the drier buzz and try pushing the little switch in and out.
Jul 09, 2009 | Dryers
Have frigidare pro series, model PLD256oLCC1 in stainless. stopped working. says "CL" on door front screen. what does this mean? how to fix?
my dishwasher is stuck on clean and when you shut the door it goes on. can't cancel wash or change wash
Jul 08, 2009 | Frigidaire Dishwashers
Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
Dishwasher not cleaning the dishes
have you cleaned the fliter in the bottom
Feb 15, 2009 | Frigidare FGB24S5DC Gas Single Oven
Frigidare dishwasher
can you give me the exact model # on your dishwasher and i will check for you.
Sep 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dryers Logo
18 people viewed this question
Top Dryers Experts
