Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore 106.56373400 ice maker not filling with water red blinking light on ice maker control
fridgetech
  • 473 Answers
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Posted on Oct 20, 2007
peyton32034
  • 410 Answers
SOURCE: Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Posted on Dec 17, 2007
  • 42 Answers
SOURCE: Light blinking on ice maker control switch
The red light on the right side of the freezer at the on off slide mechanism is normal and ok. I indicates the ice maker is not in a cycle at the time. It is not meant to tell the customer the unit is ok or it is not ok. Ignore the light.
If I helped enough please don't forget to rate as a FixYa if you need more information please request more help.
Thanks, supertechks
Posted on Feb 14, 2008
SOURCE: Ice maker not working, light blinking
This is my problem too! What is the solution??
Posted on Sep 24, 2008
  • 399 Answers
SOURCE: ice maker stop making ice for kenmore 106.56352500
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Dec 06, 2008
Kenmore
Can you check if the ice maker fill tube clogged with ice?
If the answer is Yes, it means that water valve is leaking, then you will need to replace water valve.
If not, try manually activate ice maker.
Jun 08, 2013 | Refrigerators
Not making ice!
Try removing it and let the ice thaw. The mechanism for the rake to push out the ice can freeze up.
Apr 30, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working andred light blinking
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Refrigerators
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
