Question about Black & Decker ABD500B Coffee Maker
My coffee maker will not brew
I've this Black and Decker coffee maker for only a few months and it just quit working. The brew light comes on and I can hear a switch inside click, but nothing happens.
  • 12 Answers
SOURCE: Coffee does not brew
The thermal breaker has died in it. This is usually mounted on, or near the heating elementm and usually turns off when excessive temperatures are present (such as when a pot boils dry, or the unit is left on for days) It can be checked with a ohm meter on its contacts. If it shows as good, it should show up as normally closed. Some overtemp breakers have a small button for resetting, but most are simply supposed to reset themselves once the heat is sufficiently reduced. There are also heat fuses that blow...for good when excessive heat is detected, mounted in the same place, they are often a metal bullet shaped tube. OR.....your power cord...or main power switch could also be faulty.
Posted on May 01, 2006
SOURCE: Black and Decker Dual Coffee Maker
it says 4 tablespoons per cup, but I use a heaping coffee scoop.
Posted on Jan 04, 2008
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
  • 4 Answers
SOURCE: coffee maker clicks but does not brew
Your coffee maker might be defected try calling GE to solve the problem or return it to walmart.
Posted on Mar 09, 2009
VtToolMan
  • 704 Answers
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
What can I do if my 12 cup black and decker coffee maker wont brew. Power is on
These devices are unfortunately made cheaply these days. If it is fairly new, say within 6 months, contact the manufacturers customer support line (found on documents or their website) and they often just ship you a replacement.
Otherwise, if the water is not coming out and spilling over, make sure that the release in the brew basket is opening when the pot is placed under it. Some of them stick and then the coffee overflows.
Oct 01, 2016 | Applica Black And Decker 12 Cup...
My coffer maker brew basket keeps overflowing. I've deduced that when I push my decanter into the machine, there is so much give that the plastic arm in back pushes it forward and stops the coffee from...
Hello, Srober48 -
Since your Black & Decker coffee maker is only a few months old, it is most likely still covered by warranty.
I suggest you call the Black & Decker Customer Service / Support telephone number printed in your owner's manual / instructions and find out if you can take the coffee maker to an authorized repair center (for free, warranty-covered repair) or if the company will provide you with a replacement coffee maker.
Note: I suggest you do not try to repair the coffee maker yourself while it is still covered by the warranty.
Best wishes.
Feb 04, 2018 | Black & Decker DCM100 12-Cup Coffee Maker
My black & decker coffee machine stop brewing coffee, sound like is going to keep working but is not .
Does the display work? Does the platter heat up when it is turned on to brew? If yes to both, this string might address the problem. Email me at the posted address if you need the part.
Jan 10, 2011 | Black & Decker Spacemaker 10-Cup Coffee...
I just have the regular Black & Decker coffee maker and I have the water in it and the filter with coffee, everything you are supposed to do. It used to work just fine and then one day it stopped...
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen, unscrew from the brew head where the coffee oils come into contact with machine, and filter holder in a coffee oil remover or dezcal.
Remove the screw if your filter basket has one and do not screw too tight when putting back together or it will happen again
Dec 10, 2010 | Black & Decker Coffee Makers & Espresso...
My under the counter coffee maker stopped working after only a couple of months.
Does the display work? Does the platter heat up when it is turned on to brew? If yes to both, this might be the problem and solution. Please read both (scroll).
Aug 04, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
I put the coffee on to brew and it stops after a few cups
If the display works and the platter heats up when it is turned on to brew, this might be the problem and solution. Please read both (scroll).
May 30, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
Black & Decker ABD500B Coffee Maker Logo
597 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Greg Cann
Greg Cann
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
