Question about Whirlpool GEW9250 Electric Dryer
Parts I am trying to identify what the wires are that are connected to the silver thing in the back of the whirlppol dryer.
  • 686 Answers
Are you trying to hook them back up? think of those silver things as like a light switch they tell your heat element to come on and shut off
Posted on Mar 12, 2009
Dryer wont start
I have a Maytag dryer 5600tq0 and my wife had it for 5 years. it stopped turning on. i did a trick by opening the back and locating the small white thermofuse (Part# 3392519), unhook the 2 wires attached and somehow stick a small wire to connect those 2 purple wires together. Then plug the dryer on and if it turns on, then that ThermoFuse is blown. I ordered the ThermoFuse Part# 3392519 from Appliance Parts Stop on Amazon $3.37. I also ordered the small silver n black (with 2 blue wires n 2 thick red wires attached)Thermostat part# 3387134 $5.00 from ACS on Amazon because it works together with the thermofuse and all websites say it is common practice TO CHANGE this also. then plugged everything back and it worked.
Feb 17, 2013 | Dryers
Dryer does not heat up. cleaned exhaust, tried different cycles. still nothing. possibly heating element?
On the back of your dryer there are two over temp sensors, most times one will go bad for know reason, looking at the wires on the back you will see them going into a small silver cap looking thing this is the sensor , after you unplug this dryer remove the back of this unit, follow the wires till you see the sensor this has two wires on it , remove the wires and check the sensor for continuity . And of coarse inone is found then replace this sensoe it has the part number on it and if i remember corect it was around $4 , remember there are two sensors so look for both , if you dont have a tester then remove the wires and use a small jumper wire in it's place , start the dryer to see if it heating , if it is order the sensor , do not use the dryer with out the sensor , you could get a dryer fire !!! Frank
Oct 17, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Bathroom switch controls light & fan. Trying to change out switch into a gfi switch/receptile. Box contains 2 wires ( total 2 white and 2 black, plus ground). what do i do
First you have to identify cables.
You have 2 cables that enter box. Each cable has black and white wires.
One cable probably comes from breaker box, and one cable probably goes to Load (which means your fan-light)
Separate wires for testing. Turn power ON.
Test each wire to bare ground wire. Tester lights up on Hot wire. This wire will connect to brass 'Line' screw on back of new GFCI device.
Hot is identified. Test Hot to all other wires except bare ground. Tester lights up on Neutral wire. Neutral connects to silver screw that sits across from Line screw on new GFCI device.
Other two wires inside box go to Load.
These wires connect to the two wires that stick out on back of new GFCI device.
Ground wires are connected together and connect to green screw on new device.
Apr 21, 2011 | Cooper Wiring Devices ACE AC-DC...
I am trying to hook up a gfi with a piolt light switch , when i connect and try it i blow the fuses help
Unfortunately, you don't say what wires are inside box or what lights you are connecting, or what type of switch you are replacing.
So here is generic explanation, You can add comment with more information for more free help.
Back of wiring device are markings that show Line and Load.
There are 4 screws. One brass and one silver screw for each Line and Load.
On back of device are two wires that stick out. These wires go to Black and white wire going to your light.
Electricians don't guess, they test.
Turn power ON.
Hot wire connects to Brass Line screw.
If there is another black wire that was connected with Hot wire, then this wire connects to Line brass screw.
Hot wire is identified.
Test Hot wire to each other wire, except bare ground.
This wire connects to Silver Line screw. Pilot light will come on each time switch is moved.
If Neutral wire is wrapped together with other wire(s), then this wire is a) the white neutral for light, and connects to one of wires sticking out from back of gfci. Or b) this wire is a neutral and connects to silver Load screw.
Add a comment for more free help, and say precisely what wires and lights you are connecting, and what type of switch you are replacing.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on any do-it-yourself project.
Dec 20, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
We are trying to install a levitron t5625 switch outlet combo and we have a black and white on the left side and a black wire only on the right side. How do we connect to the two screws on the right side?
See product to make sure we are talking about same thing:
http://www.google.com/products/catalog?oe=utf-8&rls
If this is not your device, add a comment any time or fixya offers phone support for a fee.
This ordinary switch-outlet combo.
One side of device: there are dark screws on one side of device: Black hot wire from circuit breaker connects to either dark screw. The dark screws are connected by a brass plate, so both screws are identical.
Other side of device: there are silver and brass screws.
Wire going to Load (light fan motor) connects to brass screw.
White neutral wire connects to silver screw.
Here's how to test for Hot and Neutral wires.
Separate all wires for testing.
Turn on power.
Tester lights up on Hot wire >> this wire will connect to dark colored screw.
Now you have identified Hot wire >> test hot wire to other wires (excluding bare ground).
Tester lights up on Neutral > this wires connects to silver screw.
Final wire goes to Load and connects to brass screw
Dec 20, 2010 | Leviton 8299 Combination Switch / Smart...
Dryer electrical supply ok but dryer control panel won't come on
If the contro lock is faulty the unit will not start. I think you have identified the problem there.
Please rate my help++++Thanks for using FIXYA
May 17, 2010 | Whirlpool GEW9250 Electric Dryer
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
Mar 14, 2010 | Roper RGS7646KQ Gas Dryer
Kenmore Electric dryer wont heat
ok take it nice n slow remove da back of da dryer after unplugging it the long silver can is da drying element close to da top is 2 two red wires connected to a thing take da wires off replace it if u call me i can tell how to fix
Jan 27, 2010 | Kenmore Dryers
HI I have a 4yr old neptune dryer that will not heat, everything else works, I have checked all I know how to check, the element is ok, I think the thermal fuse is ok the only thing I can find is a small...
Hi and welcome to FixYa,
What you are describing could either be:
  • another thermal fuse but should read '0" ohms at normal temperature / condition;
  • sensor bar;
  • thermistor.
The exploded parts diagram starting here would help you identify it. Offhand though, it would appear to be not a part of the heater circuitry but of the general controller board.
To your concern on the heater failing to heat, some pointers:
  • there are 2 temperature sensitive protective devices in series with the heater. Failure of any would result to no heat;
  • the heater is activated by 2 switches; 1 in the controller board and another inside the fan motor;
  • below is an electrical wiring diagram that may be referenced to trace where the voltage would be missing hence no heater power.
Good luck and thank you for asking FixYa.
Jul 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Connecting 4-wire recectacle 14-30r dryer power cord. i've removed neutral ground wire from dryer external ground conductor and connected it with neutral white cord wire onto center silver-colored terminal...
doesn't matter both are 110v lines but if you want look up to top screw connections the wires coming to those screws are also colored as long as the red and black are to outside screws dryer will work ok
Aug 07, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
