Question about Sony KDS-R60XBR1 60" Projection HDTV
The green light is now red and the tv want stay on and then the light turns red
  • Sony Master
  • 8,617 Answers
That model should blink a series of blinks for an error code. Let me know how many blinks and I will assist with the issue.
Posted on Dec 09, 2012
  • labricka Bittle
    labricka Bittle Dec 09, 2012
    4 red blinks
  • Sonny Berry
    Sonny Berry Dec 09, 2012
    the 4 blinks is indicating a fan has quit working and its preventing the set from operating.
5 Suggested Answers
  • 346 Answers
SOURCE: picture is geen and does not stay
bad crt
Posted on Nov 20, 2007
  • 208 Answers
SOURCE: KP65wv600
This unit is notorius for having shorted or int. shorted crts. Not good news ans this is very expensive and the crts are no longer available and can only be rebuilt by send to Video Display company.
Posted on Feb 07, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
SD Tech
  • 14553 Answers
SOURCE: I have the sony bravia KDF E50 A12U The tv went pop and wont work. On switching on the tv, the light stays green, then goes over to 3 red light flash then green. What is this and is it easily fixed?
  • This model had a problem with the lamp door warping from the heat.
Remove the door and hold it edgewise to see if warped..
There is a peg on the back of the door that engages a lever when the door is closed---if door warped set will not come on.
A simple way to confirm or deny this is to use something not metal to with the door removed ENGAGE and hold the lever forward.
DO NOT IF THE THIS SET COMES ON LOOK AT THE LIGHT OR OPERATE IT FOR PROLONGED PERIODS OF TIME.
Do not put the outer shield cover back on without the door as heat can get it also.
If set comes on with door lever engaged you need to replace the door--widely available on the internet and or from Sony---not a bad idea to buy a spare one.
let me know what happens.
Posted on Mar 16, 2012
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Sony tv prolem
If the red light that stays on says lamp check the lamp or replace it-- it may not look bad to be bad.
Apr 19, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Sony KDS-R60XBR1 60" Projection HDTV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
