Question about Emerson MW8102SS 1100 Watts Microwave Oven
Microwave turns on and counts down but won't heat up/cook
I have a microwave Emerson Model MW8117W.
It's only 2 years old.
It turns on and when you press cook it counts down, but doesn't heat up, plate doesn't turn, and nothing gets cooked.
Please HELP!!
  • 5 more comments
  • Anonymous Jan 17, 2009
    I have th same problem. Any suggestions would help. Mine is only 6 months old.
  • Anonymous Jan 21, 2009
    same, does not heat .... everything else work just fine
  • lmostrander Jan 27, 2009
    what are the indicating light in the display
    ( one is defrost with snowflacks- one looks like it is warming a tea cup etc)
  • boo2007 Feb 16, 2009
    I am having the same problem. Is this it worth fixing or buying a new one?
  • mroyse Mar 06, 2009
    Microwave turns on and timer works but it won't cook and the plate doesn't turn. The fuse is fine. I can't figure it out!
  • brandykindre Apr 04, 2009
    everything works except the heat what do i do now
  • Judy C
    Judy C Dec 30, 2017
    Woo hoo! This worked great. I used some epoxy putty to put a small plastic clip, 1/16th “, on the bottom inner door frame to raise the door when it closes and make a permanent fix.
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Posted on Mar 06, 2009
  • Christina Burke
    Christina Burke Sep 14, 2015
    Oh my gosh! So simple! We were ready to toss it, but I just pressed upward on the door (1/16 inch, maybe?) and it started working again. Thank you!!!
    New Friend:
Thanks for the great tip! Ours started acting up today and was sporadic—sometimes it worked and sometimes nothing but the light and countdown worked. Turns out it was due to door sag—pushing up when you closed it made it work consistently—what a relief with Thanksgiving right around the corner!
Posted on Nov 17, 2017
    New Friend:
For others with similar situation- I ran into this and fixed this with replacing 1 of the 2 door switches. I found someone who had the same unit and problem and he explained the whole resolution.
http://www.nouserserviceableparts.com/2011/03/31/fixing-a-emerson-mw8992sb/
I ordered 2 of these switches incase the other went at some point. Had to widen the connectors to fit the replacement part, but it works fine. It is simply a failure on a moving part that gets used everytime the door opens and closes. So when it fails the switch does not close the circuit and the microwave senses the door is not shut and will not work properly.
Posted on Jan 11, 2015
  • Todd Wright
    Todd Wright Jan 11, 2015
    Here is the exact part:
  • Todd Wright
    480-3187-ND from Digikey
    New Friend:
I was having the same problem and it turned out the door was just misaligned. I pulled up on the door until there was a click and then it worked fine.
Posted on Jan 07, 2013
Why does my Emerson MW8117W microwave turn on and start cooking when I OPEN the door?
The airbag module needs to be replace if the vehicle has not been in any kind of fender bender.
Aug 18, 2014 | Microwave Ovens
We have the emerson Model MW8117W. The light comes on, the number count down,and 2 icons are flashing but I do not know what the meaning of the first icon is. Please help
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020.
Get help locating an authorized servicer or parts at 1-800-695-0098.
Dec 06, 2009 | Emerson Microwave Ovens
My emerson mw8117w just stopped working
hi! first thing first check all the fuses for busted.
Sep 15, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Need to find turntable mount for Emerson MW8117W Microwave
Go to repairclinic.com and type in your model number. I suspect you may be talking about item 1063610, Turntable Coupler. You may also try searspartsdirect.com. If this isn't the part you need, please post back and provide more information, so that I may assist you better. I hope this helps.
Jan 04, 2009 | Emerson Black Microwave Oven
Microwave doesnt heat anything.
it is the door problem it seems to be known issue per target sales guy he advise to call emerson since it is past 90 days for target to return
Jan 19, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
6,675 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
