Question about Honeywell Heating & Cooling
Installing a Honeywell RTHL2310 thermostat on a 2 wire pellet stove. Connected to Thermostat R and W with fan option selected to gas/oil, heat rate cycle set @3. Pellet stove will not turn on via thermostat. Is there any jumpers or a different wiring required?
  • DJG35X Dec 09, 2012
    Thanks for all your reply's. Just found out the pellet stove I have (Englander 25-PDVC), only uses the thermostat to regulate temperature, it DOES NOT turn the stove on/off. Manuals say nothing about this, found a small blurb on the Englander web site under the thermostats they sell. Sure would be nice if these manufactures would put something so vital in the manuals....
5 Suggested Answers
  • 96 Answers
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
kingbrizzle
  • 407 Answers
SOURCE: I bought a Honeywell programmable thermostat
If all you have is a 4 wire system, then your new thermostat will be hooked up just as it was ( r,w,y,g) and if there is no jumper on the new thermostat, then you shouldn't need one. The jumper on some thermostats are used for internal controls and is just a way that that certain thermostat works.
Posted on Jan 23, 2010
SOURCE: Trying to hook up a RTH2310B thermostat to a wood
Hey Brad432, this is what i did with the same RTH2310B thermostat and my harmon stove. You must have the heat sensor that plugs in the back of the stove to start with. Take your new wire from the stove to your thermostat, red to rh, white to one side of your sensor then other side of sensor to W on your thermostat. On your stove side set your room temp as high as it will go and let your programmable thermostat set the room temp. Works good for mine. Good Luck
Posted on Nov 22, 2010
Need to change thermostat from Celsius to Fahrenheit
The first link is operators manual.
The second is installation and contains the procedure to set many functions including the display temperature.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2577ES.pdf
See page 15 function set 14. This sets F or C temperature
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2578ES.pdf
hope this helps?
Jun 23, 2017 | Honeywell Heating & Cooling
HONEYWELL RTHL2310/RTHL221 THERMOSTAT AIR WILL NOT COMEON
Recheck your connections.The wire colors may not have been wired in the standard way when HVAC system was installed. I remember the instructions on my Honeywell thermostat(replaced mine about 2 months ago) stated that you should look at the wire LOCATIONS on the 'stat you're replacing and tag the wires according to this,not the wire color(too late in your case).You'll have to verify the wires.Disconnect them(don't worry about noting where they were as it's not right anyway).Using an A/C voltmeter,locate the hot feed to the 'stat(ground one lead of the meter at a nearby outlet and look for 24v on any of the wires).Tag it as "feed".Now,touch this to each wire until you find one that turns on the ventilation blower and tag it.Try the other two,one of them should turn on the outside A/C condensor unit(this is the A/C wire).The remaining wire's gotta be the furnace,but verify anyway.This should be enough to get you back on track(don't feel bad,the instructions in my 'stat confused me a little,even though I've replaced mine a couple times before).PS- I think the blower fan wire goes to the terminal with the little factory jumper wire-this is so you can set it up to run the same fan in heat or A/C(factory setup) or remove the jumper to run a seperate fan for each(highly unusual setup but possible)
May 25, 2012 | Honeywell Programmable Thermostat Heater
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Trying to hook up a RTH2310B thermostat to a wood pellet stove with only two wires.. How do I know where to connect them too?
Nov 01, 2010 | Honeywell Focus 6300B 5-2 Days...
No heat after installing honeywell thermostat H8110U
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
Dec 07, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
131 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
