When I turn my computer monitor on, it just flashes.. Is my monitor out or do I need new cables?
    New Friend:
  • 7 Answers
Your monitor is out mate. If it would be cable it would turn on at least but as I can see is dead..
Posted on Dec 09, 2012
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor flashes the "AOC Eyes Value" logo without evr turning on
Man that really hurts.
Flashing logo of company on monitor screen means your monitor has power but not receiving data. Have to find a way to fix data, may be data cable ( vga cable ) of booting of computer itself
Try few things not sure solve your problem or not but really doesnt hurt to try
First, It looks you have loose VGA cabling. Try removing VGA cable completely and connect again
Link how VGA cable looks like
http://files.sandberg.it/products/images/lg/501-93_lg.jpg
Second, if above doesnt solve the problem, may be your VGA card has problem or your CPU is not booting up. Feel the breeze of fan on SMPS to see if it is working or not.
Hope this helps
May 20, 2010 | AOC 193FW LCD Monitor
The monitor won't go on after holding the power button
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 15, 2010 | Neovo F-417 17" LCD Monitor
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Analog and Digital.
Your monitor should have come with two cables. One is for analog and the other is for digital and is rectangle. Before turning on the computer connect only the Digital cable to your monitor and the video card on the computer. Most monitors will automatically seance the Digital and operate when you start up the computer. Make sure the monitor is ON when the computer starts. Your manual should have instructions that will help.
DO NOT CONNECT BOTH CABLES UP. Only the one needed.
Hope this helps. Bud
Jan 05, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Dell monitor problem
Disconnect and reconnect both ends of the video cable (while the computer and monitor are both off). Also disconnect and reconnect the power cable. Is the power cable plugged into the same surge protector as the computer? And also try a different outlet on the surge protector for the monitor.
Jul 22, 2008 | Dell E153FP 15" LCD Monitor
Monitor will not turn on
Unless you recently installed new video or monitor drivers, it sounds like either bad cabling to your computer (check the cables?) or the ribbon cable inside the LCD monitor has come unseated.
The unseated ribbon cable problem is more common if you recently moved the monitor or dropped it a bit. You can open the back of the LCD monitor (unplug it first of course) and check to make sure the signal ribbon is seated properly, this is a common problem.
Good luck...
Nov 14, 2007 | Microtek C893 18.1" Flat Panel LCD Monitor
Power light flashes with no display
That usually means that the connection between the PC and the monitor has been interupted- check that the cable (probably has blue ends) between the two is firmly connected, and power it back up. If that doesn't work, you have one of three problems; a broken VGA cable, a broken monitor, or a broken video card. Finding out which- you'll actually need someone tech-savvy there to help you figure that out. Try plugging the monitor into a different computer. If that fails, use a different VGA cable (cables are pretty cheap at monoprice.com), and if that fails, it's your video card.
May 23, 2007 | Mag Innovision InnoVision 786 PF 17" CRT...
Open Questions:
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
