Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat won't turn the furnace on after power outage.
We had a power outage last night and now there is no display and won't turn on the heat. The fan will come on if it switch it to the ON position but won't start the heat.
    Problem Solver:
  • 10 Answers
Probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Posted on Dec 10, 2012
  • 118 Answers
SOURCE: problem with thermostat (honeywell rth111/221).
should be installed with
1) red to rc and jumpered to rh
2) green to g
3) yellow or blue to y
4) white to w
to test: remove t-stat connect white and red - furnace should operate normally unitil you disconnect.
if it does replace t-stat
Posted on Oct 27, 2009
  • 168 Answers
SOURCE: honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Posted on Feb 03, 2008
  • 518 Answers
SOURCE: honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Posted on Mar 07, 2008
boanhtgclg
  • 34 Answers
SOURCE: New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Posted on Nov 12, 2008
  • 252 Answers
SOURCE: I have an old Honeywell thermostat (Chronotherm
you are not geting AC power from the furnace
Posted on Sep 27, 2009
The display on my Ampam by Honeywell programmable thermostat displays all 8s. Is it time to get a new thermostat?
"Funky" displays often indicate a problem with a control or processor. The simplest fix is removing power for a minute or two and trying again.
Doing this will likely erase any time / temperature program in the t-stat, so you should make note of it before attempting.
I'm not familiar with the t-stat you have, but if it is like most - it has a battery or two inside to maintain the program during power outages (and allows programming while in your easy chair). You should remove the battery(s) and remove it from the wall (most will simply pull away when unclipped / disconnected) to completely power down. Wait a moment and reinstall the battery(s) and reinstall to base on the wall.
Dec 03, 2014 | Heating & Cooling
Dual heat system, honeywell thermostat, auxiliary heat won't turn on
IT SOUNDS TO ME LIKE EITHER YOUR SYSTEMS LOW VOLTAGE WIRING IS INCORRECT, MOST LIKELY @ THE FURNACE. IT COULD ALSO SIMPLY BE THAT WHEN THE TECHNICIAN THAT INSTALLED THE T-STAT AT START-UP DID NOT GO THROUGH THE INSTALLER SET-UP & CHOOSE THE CORRECT SETTINGS FOR A DUEL FUEL SYSTEM. TRY THIS " SET THE THERMOSTAT TO EMERGENCY HEAT, WAIT A MINUTE OR TWO & SEE IF THAT TURNED GAS FURNACE ON. IF SO THEN IT'S A SIMPLE FIX IN THE WIRING OR PROGRAMMING & NOT SOMETHING MAJOR! GOOD LUCK!
Nov 25, 2012 | Honeywell VisionPRO Thermostat TH8110
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
I changed a honeywell thermo last night. I'm
check your transformer some of them have a little reset button on the side if it arched it could of tripped it.if there is no reset make sure you have 24v coming into thermostat.
Apr 22, 2012 | Honeywell Heating & Cooling
Just replaced batteries in thermostat and now it won't work. Batteries are brand new.
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Aug 31, 2011 | Honeywell Heating & Cooling
Honeywell T8011r does not have anything on display - does not appear circuit breaker is thrown - could it be wire disconnected at the plate or is there a fuse inside the unit?
Check to see if you have power at the furnace. You thermostat is powered by 24vac coming from the furnace. You should have power on the "R" terminal.
Oct 05, 2009 | Honeywell Electronic Programmable...
Honeywell chronotherm III air conditoner
I had that last night. I turned off the unit for a couple of hours and it came back on and ran and cooled. I have no friggin' idea if it will work but it got us through last night.
Jun 05, 2008 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
573 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
