Hi, the washing machine in question is leaking in the region of the front left hand bottom. It also seems to be overfilling and H20 flashes. Is there a pressure switch for filling that could be fault
    Problem Solver:
  • 7 Answers
There might be few reasons for that type of behiveur.But most important H20 error mean that you have to check tap and pressure of incoming watter and that's the probably why is over filling. But if pressure is ok it might be problem with valve that open for incoming water and then it should close when it have enough water but if pressure is to high it might just keep flowing in or just valving system have some kind of fault or if there's incoming water pressure to high it might be booth. Also as I don't know the exactly what's going on you could also check filtter which might be blocked or pump but if problem is only when it's starting washing and when water is flowing in I wouldn't worry about pump.
Any questions do not hesistate to contact me.
I hope I helped
Posted on Dec 09, 2012
  • 1294 Answers
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Posted on Sep 03, 2007
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
Posted on Jan 16, 2008
  • 3 Answers
Had the same problem - I posted full description in another 4E post - But my problem was a crack.split in the pipe to the sensor
Posted on Jul 11, 2008
barkencoa
  • 3463 Answers
SOURCE: fault code h20 flashing on indisit wie127 washing
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Please rate my solution.
Thankyou.
Posted on Jan 21, 2010
  • 266 Answers
SOURCE: My Kenmore 700 series washer has been leaking
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Posted on Aug 11, 2010
My washing machine flashes H20
Try to put some hot water and drain it(not too hot)
Apr 08, 2014 | Hotpoint Ultima WF860 Front Load Washer
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
May 14, 2017 | LG Washing Machines
My machine is flashing h20 and wont start why
hi my machine is flashing h20 what does it mean
Mar 26, 2011 | Hotpoint Aquarius WD640 Front Load...
Leaking from soap dispenser to front bottom door
hi this happened to me a few months ago u need to get a leak proof sealant and remove thee top of your washing machine the on the left hand side yoou will notice your soap compartment you need to seal this all the way round leave it to dry for two hours minimum then try running your machine again hope this helps.
Mar 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machine Leaked but seems ok now.
likely it was overfilled - and caused an unbalanced load that may have shifted the tub - allowing the gasket to leak.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 22422 Top Load Washer
Hotpoint Ultimasimply flashes H20.
witch one of theses are your washing machine?
lcd evo01
lcd evo02
or the V4
please let me know so i can get you the right term for the code.
Aug 14, 2008 | Hotpoint Ultima WF860 Front Load Washer
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Washers leaking
SOUNDS LIKE THE OUTLET PUMP / HOSE
Oct 21, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
