Question about Tefal Pro Express GV 8120 Iron
Our pro express GV is continual steaming?
The iron is great but just started to steam all the time even when left standing?any ideas?
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
SOURCE: Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Posted on Feb 04, 2009
  • 1525 Answers
SOURCE: 2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Posted on Mar 20, 2009
aguywithfeet
  • 20 Answers
SOURCE: Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Posted on Apr 02, 2009
heatman101
  • 43501 Answers
SOURCE: Tefal Pro Express Steam Iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
My Tefal pro iron sometimes makes noise and dont steam any more?
get rid of the calcium,and use distilled water for steam,not tap water
Jun 20, 2015 | Tefal Pro Express GV 8120 Iron
Steam button is broken on my iron
Replace iron, or continue using the iron......without the steam button.
Apr 02, 2014 | Tefal Pro Express GV 8120 Iron
Plug iron in but its dead
follow the next steps and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord +thermical fuse with VOM . Also test and, if needed, adjust calibration of the thermostat (
Nov 14, 2012 | Tefal Pro Express GV 8120 Iron
Steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
May 08, 2012 | Tefal Pro Express GV 8120 Iron
I'mnot getting any steam from my tefal steam iron.
Please bring your unit or call a service center accredited by manufacturer of your unit. The temperature needs some adjustment inside the unit. Check also if the unit has electric power and hope you do not forget putting water in the steam.
Jun 14, 2011 | Tefal Pro Express GV 8120 Iron
Continuous steam and green light flashing on my tefal steam generator iron.
I found this on a site and it works!! Put 50/50 mix of water and viniger in your iron, let it run, after a while start pressing the steam button, you may have to do this a few times, but it will eventually stop the light flashing, then the steam function will return to normal. You'll need to clean the iron out a few times afterwards
Jun 22, 2010 | Tefal Pro Express GV 8120 Iron
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Tefal Pro Express GV 8120 Iron Logo
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
