Question about Mitsubishi WT-46805 46" Rear Projection Television
Mitsubishi WT-46805 convergence resistor location and vlaues
Can anyone tell me the locations and values of the convergence resistors on this model
thanks
  • 3 more comments
  • dcxguy48080 Jan 13, 2009
    hey can i get your email address i want to send you a picture of what the problem is........and if you could please give me the resistor locations i would appreciate it......i found 18 but they were all like 5.6 ohm......i did see a module next to the stks....it said like green something near it...green gene?
    better yet here is my email address dcxguy48080@yahoo.com
    email me so i can send a pic....
    i also can not move blue or red at all during convergence and when i go into service mode and try to cahnge gemoetry nothing happens at all for red or blue or green.........the picture looks just like this see link
    and scroll to bottom of the screen on that link you will see a pic of red blue and green way off and bowed in thats exaclty how mine looks
    http://www.riddledtv.com/forums/mitsubis...
    is the board you are referring to called the conv gene board???
    i have seen other references to that regarding not being able to move convergence at all for all colors...........
    you mentions some caps.10uf 16v?...similar to hypermodule on toshiba???
    on this model i saw 18 resistors that said like RD they were right near the stk in groups of 9
    they all checked like 5-5.5 ohm......you said 120ohm
    can you verify the actual locations or no schematic??
    hi i pulled out the conv gene board if thats what you are referring to and the capacitors all look fine..none are bulged at all.......and there are about 25 of them on the baord...some say 10uf50 and some say 16v47uf
    i thought that when caps go bad you should see a bulge on top or is this not always true..and do you think its this board casuing the convergence to not work at all........ic ant adjust blue red or green at all even after replacing the stk and finding no bad resisors and no bad picos
    Champion:
  • 240 Answers
5a resistors are all 120 ohm 1/2 watt use flame proof resistors.
check fuse f9a23 or f9a22
also replace knowen bad caps in this unit efecting convergence replace all 10uf @ 16v on the scan doubler module, ther are 8 off them.
make shure and check trace between Rg-8 and r705 for a open, sumtimes fulid from crt will open this up.
regards
daniel.
Posted on Jan 13, 2009
  • 1 more comment
  • Daniel Conklin
    Daniel Conklin Jan 13, 2009
    yes about the same, in ref to caps, your right.
    please rate me if this was of help
    i work very hard giving out free advice you know.
    lol
  • Daniel Conklin
    I think all resistor locations star with 5a or sa
  • Daniel Conklin
    also get a magnifine glass look for small cracks in the resistors, I have fixed manny like this in the past.
I replaced my convergence chips and I still have a convergence problem. Its not as bad but I still cant line up the blue convergence cross exactly
Sounds like your over half way there lol..
You now need to check the resistors positioned near the convergence ic's. They are your likely problem and go bad often when the ic's fail.
They are normally about 2watt and the values will vary but normally are like .10 ohms to 1 ohm.
I cant find a schematic to give you the exact values and locations but if these resistors measure off value at all you need to replace them with the exact value of the originals.
Heres a link to resistor color code guides just in case the value numbers are not printed on the resistors
http://www.dannyg.com/examples/res2/resistor.htm
Good Luck!!!
Nov 24, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
How do I locate resistor values?
Click HERE to download service manual copy for free. Download all 12 files and unzip with winrar to get pdf file.
Hope this will help you to find out required resistors value.
Oct 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Convergence on mitsubishi WT-46805
Mitsubishi is famous for this. You are going to have to resolder the convergence ICs. Very simple repair if you are just a little tech savy. Do you know how to solder? This is a 99% fix. Take the back cover off (unplug first). You will see a big heatsink on the board (6-8 inchs long) attached to this are 2 convergence ICs. Unscrew the board, flip it over and resolder all the pins to those 2 chips. Done
Feb 11, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mits 46805 - Replaced IC's now picture is dim!
Good Day, Nickb2b;
The IC's you installed will not cause a dark/dim picture......but I would like you to check two things:
1. Make sure you put all cables that you may have unplugged into their proper positions, the cables are marked with numbers, ensure all cables are properly seated,
2. Look for fluid on the PCB's.
Good Luck, big IRISH.
Jun 21, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi big screen tv model no. wt-46805 year2000
Replace the convergence amp ICs. also shck the resistors coming out of the ICs
Jan 30, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Hourglass Picture
it easy to locate the fusible resistor in the power module PCB,it look like a resistor but white in color,normally printed soc xxxx (2100) on top of the component. After you replaced the STK392-110 , you need to re-alight the convergence setting again.hope it will help.
Aug 03, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
