Question about Jabra Journey Bluetooth In-car Speakerphone
My Jabra Journey device do not talk anymore. It does not say "connected" or "disconnected" or the in-coming call phone numbers. It only makes a musical sound
SOURCE: My Jabra BT160 won't connect to my Nokia 6103 why?
Try what Shelley says above...hold down the button while you search on your phone. It was the only thing I could get to work with my Jabra and Nokia phone.
Posted on Jul 02, 2008
SOURCE: jabra bce-250
how to connact nokia 6300 with jabra bce-205 wireless headset
Posted on Feb 06, 2009
  • 638 Answers
SOURCE: i change my handset now jabra bt125 is not
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Password is 0000.
Posted on Dec 22, 2009
BoraDURSUN
  • 47 Answers
SOURCE: Connecting cell phone and Jabra
Check that both devices are BT enabled and in pairing mode -ie, leds blinking-. If one of the device is not in pairing mode, it is normal that the process fails.
If you experience the same problem on other phones with your Jabra BCE-250 -same as mine-, you might think of getting it checked first.
Posted on Jan 07, 2010
SOURCE: How to connect my jabra
hold the answer button and the power button in for 5 seconds until you get a solid light, then add device to your phone and follow thru with the pairing procedures as prompted on your screen
Posted on Oct 02, 2010
How do I "pair" the Jabara Journey with a I Phone 5C?
most pairing when asked by the device requires a 00000 passcode
but you need to set the jabra and the iphone up for pairing
here is a link for jabra the iphone should see it when the jabra is set to set up mode..
http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
Oct 11, 2013 | Jabra Cruiser InCar Speakerphone Black
Technical support for jabra journey MODEL HFS003
Can I connect my Jabra Journey Model HFS003 to my car radio to listen music, conversations, etc by my speaker's car?
Aug 14, 2012 | Jabra Cruiser InCar Speakerphone Black
Jabra talk ps3 problems
i got the same problem. hope sum1 knows whats wrong cuz i dont.
Aug 09, 2012 | Jabra Cell Phones
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
I have the Original Jabra Stone Bluetooth Headset and I need to know to connect it with my phone with is an HTC Desire.
I'm not familiar with the HTC desire, but most cell phones are much the same when it comes to connecting a bluetooth device, you would go into your settings looking for bluetooth device, some phones it's under options, you want to make sure bluetooth is turned on, discover, or discoverable is turned on, then select search for new devices. Make sure the Jabra is on before performing the last step. It should discover the device then it will ask you for an access code, which is usually 0000 (four zeros). Keep smiling. :)
Oct 14, 2010 | Cell Phones
How can I pair my Jabra BT2035 with my ps3
After registering the bluetooth device ( in the settings> accessory settings> register bluetooth device) you must then go to the audio options in the settings >accessory settings >audio options and switch the input from do not use to use to the name of your bluetooth to turn on the connection from the bluetooth to your ps3
Apr 16, 2010 | Jabra Cell Phones
I change my handset now jabra bt125 is not
Password is 0000.
Jul 03, 2009 | Jabra BT125 Headset
Problem pairing
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Jan 27, 2008 | Jabra BT130 Wireless Headset
Jabra Journey Bluetooth In-car Speakerphone Logo
56 people viewed this question
Top Jabra Audio Players & Recorders Experts
Tom Chichester
Mister Danger
jeff tilburn
jeff tilburn
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
